Scanner/Code Reader
Old Nov 25, 2012 | 10:59 AM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Default Scanner/Code Reader
Looking to buy a code reader for my toolbox. The choices vary in price from about $60 to over $250. Does anyone have a recommendation?
Old Nov 25, 2012 | 12:04 PM
Vette_DD's Avatar
Vette_DD
My recommendation is that you post a WTB ad in the C6 Parts for Sale/Wanted forum.
Old Nov 25, 2012 | 12:54 PM
C6ToGo's Avatar
C6ToGo
I like mine from Amazon. Basic reader that is cheap and works well.
http://www.amazon.com/Autel-MaxiScan...ywords=obd+can
Old Nov 25, 2012 | 02:28 PM
Bill Dearborn's Avatar
Bill Dearborn
Depends on what kind of maintenance you want to do. Engine and powertrain codes can be read with a cheap scanner, you can get a little more sophisticated and get some bells and whistles that let you look at the data and print it out but you are still stuck with a limited scanner that is limited to the Powertrain. From there you can get scanners that will do Powertrain and ABS and ones that can do Powertrain, ABS and Air Bag codes. The most expensive scan tools ($400+, AutoEnginuity base with GM Extension) will give you access to all of body and chassis codes plus perform some of the command functions the Tech 2 performs. If the car is stock you probably will not see a lot of powertrain codes. In owning C5 and C6 Vettes since 1997 I have only seen 3 or 4 powertrain codes show up across 3 cars over those 15+ years. Same goes for the other vehicles I have owned. Have seen a lot of ABS, and Body Codes though.
Bill
Old Nov 25, 2012 | 03:11 PM
Don-Vette's Avatar
Don-Vette
Looks like a nice stocking stuffer for my sons!
Old Nov 25, 2012 | 05:15 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Bill
Thanks for the info Bill, your insights are useful to me.
Old Nov 25, 2012 | 10:28 PM
TroyPyles's Avatar
TroyPyles
With the C5 you can read the codes on the DIC by holding down the Options button while pushing the Fuel button three times. Can't you do this with the C6 also? If you can why would you need a scanner?
To Scanner/Code Reader
