Really need help
Old Dec 2, 2012 | 02:25 AM
ultraspeed's Avatar
ultraspeed
Default Really need help
Once again, I find my self needing some assistance. I searched and searched all over the web and I am unable to find the answer i need to be sure on what my issue is. So I will do my best to explain it.
I just got done installing DP direct drive. I put the car all back together and started her up to go take her for a spin to make sure everything was good. When I started the car to let it warm up, there were no issues. So I pull the car out of my driveway and go about 200 yds and oil pressure gauge dropped to 0 and the DIC yelling at me telling me power restricted. So I hoped on here and did some research and replaced the sending unit. So after getting that in I started the car back up and i am still having the same issue oil pressure gauge reads zero and DTC yelling at me. Now the oil pump in thr car is not that old it is about a year old and has like 5-6k miles on it. BTW it is a Mellings high volume. I started doing some trouble shooting I disconnected the plug from the pressure sensor and held the acc for 5 sec to engage everything to see if the gauge would go up, and it did not. Is there a away I can check the wiring to make sure the sensor is actually getting power to jump it and rule out everything. I really want to be sure if it is a oil pump, since I just put one in not that long ago. BTW never had issues before with oil pressure.
Also any other ideas are welcomed. Sucks to put a new part in and not be able to go enjoy it.
Old Dec 2, 2012 | 07:21 AM
calemasters's Avatar
calemasters
I can use a DVOM to check the oil pressure circuit, and you can install a manual oil pressure gauge to determine if the engine has oil pressure.
Old Dec 2, 2012 | 10:17 AM
ultraspeed's Avatar
ultraspeed
Would you be able to please tell me which wire should have power to it when I hold the acc button down for 5 seconds. In other words can you walk me through reading the wires out
To Really need help
