E3 Plugs
Old 12-05-2012, 10:54 PM
hawkandersonjr
hawkandersonjr's Avatar
Location: US-ARMY 1974-1996 Retired ; Oklahoma, City ; Atlanta, Ga: Hephzibah, Ga
Default E3 Plugs
Just wondering if anyone uses these plugs in their vette. " E3 Premium Special Electrode Automotive Spark Plug" and what was the results.
Old 12-06-2012, 06:19 AM
glenB
glenB's Avatar
St. Jude Donor '08-'09 & '12, '14
Marketing hype.
Old 12-06-2012, 06:54 AM
C5Natie
C5Natie's Avatar
Those are garbage. Just install some AC Delco's or NGK's and be done.
Old 12-06-2012, 09:05 AM
Ketchum
Ketchum's Avatar
There is a G.M. TSB out on pulse duration plugs causing misfire and charge system issues. No TSB but a few posts on the Dodge sites with same issue.
Old 12-06-2012, 11:13 AM
hawkandersonjr
Thanks for the info will stick with the stock plugs.
Old 12-06-2012, 02:34 PM
Ketchum
Ketchum's Avatar
You can use 'other' plugs just not a pulse duration type plug. Some of the other members may chime in about what plugs work good.
Old 12-06-2012, 02:37 PM
Markallamerican
Markallamerican's Avatar
Originally Posted by glenB
Marketing hype.
I agree. Remember 'Splitfire' plugs?
Old 12-06-2012, 03:06 PM
Vette5.5
Vette5.5's Avatar
I've seen E3 plugs tested on the weekend Hot Rod TV shows in older style engines with positive results. But have also heard, they tend to interfere with computers on some modern cars. Think I'd stay away from them.
Old 12-06-2012, 03:10 PM
Vinnie T
Vinnie T's Avatar
The stock iridium AC's are great plugs. Just use those or something coparable like NGK or Denso iridiums.
Old 12-06-2012, 03:21 PM
AWARE02
AWARE02's Avatar
St. Jude Donor '15
If you want "mis fires go for it.Like one of the early posts said "snake oil" My $.02 worth!!
Old 12-06-2012, 04:33 PM
j_digi454
Support Corvetteforum!
j_digi454's Avatar
If you use anything other than iridium plugs, you may have charging issues, I and many others did. Do a search, there is plenty of info on the Forum about the use of non-iridium plugs.
Old 12-06-2012, 08:52 PM
RnLi
RnLi's Avatar
And speaking of spark plugs.......
I've always wondered about the "hotter spark/larger spark" plugs. Does it really matter?
I mean if you have a gallon of gas and hold a match to the open lid, it goes boom. If you have another gallon of gas and hold a blow torch to it, isn't it the same boom?
Not joking, here. Just don't understand the theory.
To E3 Plugs
Quick Reply: E3 Plugs
