Rear view camera for c6
Old Dec 7, 2012 | 10:45 AM
bluecpe's Avatar
bluecpe
3rd Gear
Default Rear view camera for c6
Does anyone know if any rear view cameras work with the stock Corvette GPS systems in 08 Vette.
Old Dec 7, 2012 | 01:44 PM
50 4Ever's Avatar
50 4Ever
Wil Cooksey #256
Short answer is NO. The stock radio only has 1 A/V input. So that's why you can only get GPS OR an MP3 player from the factory.
I choose to put in an aftermarket radio into my 08. I have front and back cameras (I use the front camera all the time, hardly ever use the rear camera). I went with a Pioneer AVIC Z2.
To get a camera to work with the stock 08 GPS you will need to get some kind of adaptor that has two A/V inputs. Check with a stereo shop that does cameras also. When I was looking in 08 there was one available, but I would have had to remove the radio and send it somewhere to get this added. And of course the warranty on the factory radio would probably have been voided.
Good luck
Old Dec 7, 2012 | 01:51 PM
4SUMERZ's Avatar
4SUMERZ
I think you will need a Corvette 360 Lockpick. It provides a video input for a camera, plus other neat features.
Old Dec 7, 2012 | 09:16 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Installation is said to be a bit tricky, some guys have done it themselves with no problems; but another posted that his stereo shop worked on it for several hours and gave up.
Someone else posted about installing a flip-up (or was it flip-down?) screen above his right knee, looked practical. And a Forum vendor posted about installing a Camaro mirror with the camera display in there. Took some work but not overpowering.
If I decide not to buy a C7, I'll probably do one of those options to our C6.
Old Dec 7, 2012 | 09:49 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
there is no Lockpick 360 anymore. They have been discontinued. There was way to many returns and problems with them.
I used to talk about 20 people a week out of spending 350.00 on a piece of junk
Your only option is for an aftermarket radio.
I have many options to help you with that should you want to replace radio. Just give me a call
608 568 3011
Old Dec 7, 2012 | 11:58 PM
4SUMERZ's Avatar
4SUMERZ
A flip down like this? That's what I installed. It works great, and out of the way when not needed. My monitor is for a front camera mounted atop the air deflector.
Flipped down for using camera
[IMG][/IMG]
Flipped up when not in use
[IMG][/IMG]
Old Dec 8, 2012 | 08:03 AM
sxs191's Avatar
sxs191
[IMG][/IMG]
[IMG][/IMG]
That is pretty nice. What model/brand is that? I was looking on line last night and couldn't find anything I liked.
Thanks.
Old Dec 8, 2012 | 09:00 AM
bluecpe's Avatar
bluecpe
3rd Gear
Thanks guys for all the info, if I do decide to go for a camera I would go the flip down route. Seems the easiest and leaves everything stock . My car is a 4LT optioned coupe missing just the adjustable suspension and the dual mode exhaust which is the only thing I was thinking of changing, but I haven't heard an exhaust sound to my liking yet.
Old Dec 8, 2012 | 11:34 AM
kellf190's Avatar
kellf190
608 568 3011
REALLY? I have a lockpick which I installed myself and it works great! I also just looked at the website and it sure looks like you can still order one. The mod to the Nav unit is a bit trickey if you are not used to working with ribbon cables connections.
Old Dec 8, 2012 | 11:55 AM
4SUMERZ's Avatar
4SUMERZ
Thanks.
I bought a 4.3'' Color TFT Car Monitor from Amazon.
It was a good price for my experiment of mounting the monitor. If it failed miserably, I was only out a little money. I took the back cover off the monitor, attached it a small door hinge with (2) tiny nut/bolts, replaced the cover, and attached the hinge under the dash as seen in the photos. I just drilled 2 small holes under the dash, which would never be noticed if the camera monitor was removed at a later stage. In order to keep the hinge tight, I removed the pin, bent it a bit, and re-inserted it in the hinge. The hinge/monitor stays up, and does not flip down until the Operator wants it to.
The site has all the different cameras that can be used for backup, or front facing applications.
This is a pic of the front camera mounted position. The material on top of the camera is heat insulation to keep the heat from the radiator away from the top of the camera.
[IMG][/IMG]
Where the camera is mounted, it gets over 150 F when the car is idling at a stop light in summer heat.
I had a remote thermocouple temporarily attached to monitor the temp in that area prior to putting on the insulation. I bought my night vision camera from the same place, and it has worked wonderfully.
Good Luck
Last edited by Vette_DD; Dec 8, 2012 at 09:21 PM. Reason: Non-supporting vendor info.
Old Dec 8, 2012 | 12:15 PM
Captain TJ's Avatar
Captain TJ
I have one too, and it works great! The wife said that I would never get it back together, great incentive. The install is not for the squeamish, but I did it!
Old Dec 8, 2012 | 12:18 PM
0Double D Mods
Former Vendor
Try calling them.
They will tell you the 360-2 for the Ford and Corvette are not available.
We sell a couple grand worth of CHR550 and V5 every week and I talk to Coastaltech weekly. They told us they do not have them as parts are not readily available to make them and a disc item at this point
They are worthless and nothing but a problem waiting to happen
For someone to spend 350.00 on one is pointless if you ask me and here is why
if you but say our Pioneer x940BT aftermarket nav package for currently 699.99
send in mail in rebate for 100.00
sell the stock NAV unit for 400.00
add the rear camera in a Pyle rear cam for 30.0
you have 229.99 into this aftermaret install all said and done
Buy the Lockpick at 350.00 add a Lockpick camera for 80.00 that is 430.00 to add a camera and you still have the horrible stock NAV in some cases no Ipod no A2DP streaming.
200.00 more to add the Lockpik and a camera than the Pioneer is
With the Pioneer you get a boat load more features too
Old Dec 8, 2012 | 07:59 PM
Gearhead Jim
St. Jude Donor '13
That's the one!
Nice work, and thanks for re-posting.
Old Dec 8, 2012 | 08:25 PM
Captain TJ's Avatar
Captain TJ
Try calling them.
And how do the steering wheel controls work?
Old Dec 8, 2012 | 08:28 PM
0Double D Mods
Former Vendor
actually yes they do for 50.00 more and its still less
Old Dec 8, 2012 | 08:33 PM
Captain TJ's Avatar
Captain TJ
That's great, it wasn't an option that I found when I did the install of the lock pick. It was the main reason that I went with it. If it ever fails, I now have another option.
Old Dec 8, 2012 | 08:35 PM
0Double D Mods
Former Vendor
I just like to break everything down for everyone who called me to buy one and show how you can really upgrade and end up spending for less money AND be happier with final results too
To Rear view camera for c6
Old Dec 8, 2012 | 08:47 PM
Gearhead Jim
St. Jude Donor '13
Now all we need is an aftermarket unit that will interface with the HUD.
Old Dec 8, 2012 | 08:51 PM
0Double D Mods
Former Vendor
We will have that around April with Kenwood
We will be able to get song info to display in the HUD but not the NAV at this time when we release the new harness. This is going to take a major change in the software from Kenwood/Garmin to match what GM has to get the NAV to display. Maybe for 2014 units
Old Dec 8, 2012 | 09:23 PM
Vette_DD's Avatar
Vette_DD
Commercial posting
Supporting vendors pay for the considerable bandwidth charges on the Forum, making it free for the rest of us. In exchange, they get the privilege of using the Forum to market and promote their goods and services.
Members are not prohibited from mentioning it when they have a good (or bad, for that matter) experience with a non-supporting vendor. But such mentions cannot be so specific (address, phone number, e-mail address, URL, price, part number, offer to send contact information via PMs, etc.) or so frequent that they become marketing and promotional references.
http://forums.corvetteforum.com/foru...l-posting.html
