interior heat shield.
Old Dec 17, 2012 | 09:54 PM
vig1116's Avatar
vig1116
Default interior heat shield.
I know it's been written here many times but of course when you need it you can't find it. I have my center console and arm rest console removed in anticipation for a couple of xmas gifts coming next week. While they are off i would like to put some heat shield over the tunnel on the inside. Whats the best/cheapest product to use that can be bought asap?? Every search i do gets me to tunnel plate threads and im looking for interior, not exterior.... Thanks guys
Old Dec 17, 2012 | 10:00 PM
MKenM's Avatar
MKenM
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
Some of the stuff out there is pretty expensive. Check out some of this you can be the judge.
Heat Shield Material
Old Dec 17, 2012 | 10:04 PM
vig1116's Avatar
vig1116
i saw that earlier and the first one for 36 bucks is perfect but its a special order. Are there any stores that stock stuff like this?
Old Dec 17, 2012 | 10:53 PM
vig1116's Avatar
vig1116
i was able to order Thermo-Tec 14100 24" X 48" Cool-It Mat from amazon and it will be here by wednesday. I hope this does the trick!! Thanks Ken!
Old Dec 17, 2012 | 11:30 PM
Kvothe's Avatar
Kvothe
One member posted where he put in some of the heat shield material you can get in the plumbing dept at the hardware store.
Do a search for kevlar hand pads on the internet. They are used in welding applications. You might be able to make one work for you. Magid Glove has them and I'm sure others do as well. Less than $10.
Old Dec 17, 2012 | 11:33 PM
Fiss's Avatar
Fiss
http://forums.corvetteforum.com/c6-c...ation-kit.html
Old Dec 18, 2012 | 01:37 AM
Mike's LS3's Avatar
Mike's LS3
When I installed my MGW shifter, I purchased Dynamat heat/sound insulation sheets and installed them under the shifter console and center consul which has reduced the heat considerably. I bought two 10" x 10" sheets that did the entire job for $10.00. You might find some at an auto parts store. During the install video of the MGW shifter there are step by step instructions on how to apply the Dynamat. Very easy, self stick product and the product did not interfere with the re-installation of the console.
Old Dec 18, 2012 | 07:45 AM
Ozarkwoods's Avatar
Ozarkwoods
There is a lot of options out there I did my diesel compartment on my motorhome with material like this.
http://www.heatshieldproducts.com/pr...felt-mat/77/37
If you do a google search for engine compartment heat shield you will get all sorts of ideas.
If you are a do it yourself make your own patterns using a felt or some material easy to lay down and cut in the car. you can buy this in different sizes, then aluminum 2" tape to seal the seams. I would say sounds like a great winter project.
Old Dec 18, 2012 | 10:31 AM
vig1116's Avatar
vig1116
thanks guys!! I should be getting the thermo-tech tomorrow and i hope it helps. if not i didnt realize dynomat was so cheap, i would hae bought that instead, but it's only a small area im doing so im sure the thermo will do just fine... Thanks guys
Old Dec 18, 2012 | 02:03 PM
Thrash's Avatar
Thrash
I put down VetteNuts heat shield AND two 12" x 9" soldering heat shields (from Low*s), no heat transmitted at all now ...
Old Dec 19, 2012 | 01:51 AM
IAIA's Avatar
IAIA
I've looked and searched but can't find any specific directions on removing the center console....any help? I know it's easy because I've seen it done, but I'd feel more comfortable prying off the brake shroud, for example, if I was sure it just clicks off.
Thanks for any thread anyone knows about.
Old Dec 19, 2012 | 05:26 AM
vig1116's Avatar
vig1116
are you talking abut the armrest part, or the radio bezel?
here's one write up: http://forums.corvetteforum.com/c6-t...l-removal.html
Old Dec 19, 2012 | 12:15 PM
Thrash's Avatar
Thrash
I did a step-by-step posted here, but it isn't easy <CLICK HERE> ...
Old Dec 19, 2012 | 12:29 PM
Don 79 TA's Avatar
Don 79 TA
i know you want interior but...
the temps inside my wifes 05 greatly went down when we used the EE tunnel plate (SUPER easy to install), 160 stat, headers, and the console box and cup holder thermal insulation
hardly ever feel any heat inside compared to what it was before the upgrades
i gather sticking insulation/matting in from DEI would help as well if you aren't interested in changing the plate
Old Dec 19, 2012 | 08:45 PM
IAIA's Avatar
IAIA
Yes, I meant the radio bezel. I want to put some sound deadening material just locally around the shifter/gearbox area because of the torque tube noises. I had a friend switch from the stock shifter to the MGW and back to stock, so know it's fairly straightforward...but this write-up is exactly what I was looking for. Don't want to mess anything up. I must've done this >10 times on my C5, but that's a bit easier.
Thanks!
Old Dec 19, 2012 | 08:47 PM
IAIA's Avatar
IAIA
This is also an excellent write-up and photo record...but it's way beyond what I want to do esp. the dash gages and seat removal. Nice work though!
Thanks.
To interior heat shield.
