A tire question
Old Dec 21, 2012 | 07:15 AM
LIE2ME's Avatar
LIE2ME
Veteran: Marine Corps
Default A tire question
My 2012 coupe has about 9000 miles on it. About how much longer should I expect the original Goodyear runflats to last?
Old Dec 21, 2012 | 07:25 AM
Tonylmiller's Avatar
Tonylmiller
Measure the tread depth.
I would expect most people would get another 10k to 20k, depending on a lot of factors.
Old Dec 21, 2012 | 09:04 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
From what you read here on CF, not much longer. But as tony says above, measure the tread depth (a gauge costs about $1.50 at any auto store), and make sure you do that measurement all the way across the tread to the inside of the tire as well.
Old Dec 21, 2012 | 09:08 AM
R&L's C6's Avatar
R&L's C6
On a regular coupe you can expect about 20k miles on the front and 30k miles on the rear. Now if you you're talking a Grand Sport, that would be a different story.
Old Dec 21, 2012 | 01:33 PM
carpe dm's Avatar
carpe dm
It depends on your alignment and driving habits. If you have that many miles on them, both are probably OK. Measure depth.
Old Dec 21, 2012 | 02:00 PM
CO Lightfoot's Avatar
CO Lightfoot
Have you had a 4-wheel alignment? The factory alignment can be way off.
Get down on the ground and completely examine each tire all the way across. If you see an unusual wear pattern -- like excessive wear to inner edges -- get an alignment ASAP.
Old Dec 21, 2012 | 02:43 PM
Red08's Avatar
Red08
My'08 coupe still has the OE Goodyears, with just over 23,000 miles. The rears still seem to have reasonable tread, but plan to replace sometime next year anyway. Why take chances.
Old Dec 21, 2012 | 03:32 PM
Jimini's Avatar
Jimini
On my 05 I got 24000 out my first set of GY supercars.
Old Dec 21, 2012 | 04:49 PM
Al Gumby's Avatar
Al Gumby
I felt I was taking a chance from the get-go with those Goodyears! Slippery tires! My `08 had 22,000 miles with plenty more left but I swapped out for Michelin PS A/S ZP's. It was 34 degrees and raining during my commute this morning and NO slipping with the Michelin's.
Old Dec 21, 2012 | 04:52 PM
Rogers 07's Avatar
Rogers 07
My original GY's lasted 16000 miles, the good sticky part was done at 6000. I will not buy a another set of the GY supercar tires. Firestones or Michelins are the way to go !!!
Old Dec 21, 2012 | 07:35 PM
MisterMidlifeCrisis's Avatar
MisterMidlifeCrisis
I have 2011 Coupe with 16k hard miles though no track miles. I got a zero-toe alignment very early on, followed up with Z51 sways and poly bushings to keep the tires flat to the road. These tires look like they'll go 30k miles front and rear even with canyon carving and taking corners quickly. It's a shame they are wearing well, because they have very little wet grip any more and are noisier than I would have imagined they would get, and that's with a few layers of sound insulation that I've put in.
Old Dec 21, 2012 | 08:14 PM
c54u's Avatar
c54u
To A tire question
