start the engine
turn on the radio
push & hold the "H" or "M" button for 5 seconds or so (until it beeps)
then push the **** that controls base/treble/etc. (each time you push this **** it toggles the hours setting)
Well, maybe. I think I discovered another set of instructions that are slightly different.
To change the time default setting from 12 hour to
24 hour, press either the H or the M button for
two seconds to enter the clock mode. Press the tune
**** to select between the 12 or 24 hour display format.
The clock mode will automatically time out with the
changed display format set as the current default setting.
So, I'm not sure which is correct.
Let me know which one works. I can't try it because my C6 has the Navigation radio.
That worked...actually, they are pretty much the same as the 'tune' **** also adjust the bass/treble.
I must have inadvertently hit it before when i was adjusting the clock.
I wonder why i couldn't find those instructions in the manual??
thanks again.
I looked in 2 different owner's manuals, the 2011 and my 2012 and those instructions are not there.
Form member Scissors posted those in 2004. but I don't know where he got them. Not sure where I got the 2nd set, but if they're the same, glad you cleared that up.
I have a '12 GS 1LT & recall seeing something in the manual...but...the radio clock continually reverts back to 24hr time...maybe I'm pressing something inadvertantly..dunno...but I'll try this from the earlier post;
That seems strange the instructions say that the engine has to be started....
Originally Posted by JimTN
Base radio with no NAV system:
to cycle back and forth from 12hr to 24hr:
start the engine
turn on the radio
Setting the Clock
To set the clock:
1. Press and hold H until the correct hour displays.
2. Press and holdM until the correct minute displays.
The clock mode automatically times out with the
Setting the Clock
To set the clock:
2. Press and hold M until the correct minute displays.
Sorry, but where in those instructions does it tell you how to switch back and forth between 12-Hr format and 24-Hr format?
Clock
To set the clock:
out with the changed display format
To set the clock on a navigation
system, see the separate navigation
manual.
Manual instructions for NAV screen clocks:
Setting the Clock
To set the time:
1. Press the power/volume **** to
turn the system on.
2. Press and hold the time display
in the upper right corner of any
screen.
3. Select the 12H or 24H screen
button to display the time in
standard or military time.
4. Press and hold the Hour and
Min. (minute) arrow buttons to
increase or to decrease the time.
5. Select the correct time zone
screen button.
6. Select the Daylight Saving Time
screen button, if necessary.
The radio uses the GPS satellite to
set the time. The vehicle needs to
be in an open area to receive the
signal. See “Clock” under AM-FM
Radio on page 13 for more
information.
AND:
Clock
Press G at the bottom of the audio/
adjust screen or press and hold the
time display in the upper right
corner of any menu to access the
CLOCK ADJUST menu. Pressing
the time display also displays the
date on the status bar at the top of
the screen.
The following time options can be
adjusted from this menu:
Hour/Min.:
. Press the up or down arrows to
increase or decrease the hour or
minutes.
. Press and hold either arrow to
advance quickly.
12H/24H: Press 12H to display the
time in standard time, or 24H to
display the time in military time.
GPS TIME: The current GPS time
is displayed to the right of this
button. Press GPS TIME to set the
navigation system's time to match
current GPS time.
Daylight Saving Time: Press this
screen button to increase the time
setting by one hour, then press GPS
TIME to save the new setting. If the
screen button is light blue, the
daylight savings time feature is on.
If the screen button is dark blue, the
daylight savings time feature is off.
TIME ZONE: The selected time
zone appears to the right of this
screen button. Press TIME ZONE to
toggle through the available time
zones until the desired time zone is
highlighted. The time of the selected
zone is displayed to the right of
GPS TIME. To set the system clock
to the new setting, press
GPS TIME.
If the system is not receiving GPS
information, the time can still be set
manually as described above, but
GPS TIME and Daylight Saving
Time features are not available.
Press the back screen button to go
back to the previous menu.
