DRL at night?
I am in the middle of installing switchbacks and i just started it about a half hour ago and the lows and DRL was on, wasn't driving it though just started it to see if lights came on...
PS i think they switch off when the highs come on, no?
The brighter filament is used for the DRL's and the turn signals.
The dimmer filament is used for the running and parking lights.
In the daytime with the lighting switch set to 'Auto', the brighter filament is lit and will flash on and off if the turn signals are used. If you have an A6, the DRL's only come on when the car's in gear.
If you leave the lighting switch in 'Auto', once it gets dark the low beams will turn on and the DRL's will change to the dimmer, running light condition. In the dark the turn signals will still light the brighter filament when they are used.
Any time, day or night, that you turn on the low beams or fog lights, the DRL's will go off and the running lights will turn on.
High beams have no affect on the DRL's, or the turn signals or the running/parking lights. However, using the high beams will switch off the fog lights if they are turned on.
Since the DRL's can only be turned on with the lighting switch set to 'Auto', there is no way to turn them on in the dark because the car will always automatically switch to the low beams/etc.
And, there are no fuses for the DRL/turn signals, they are controlled/regulated directly by the BCM (computer).
Hope this helps.
Hope this helps.
umm, yeah, that's what i meant...
During the day, you can turn off the DRL's after starting the engine, by rotating the headlight switch fully "rearward, toward yourself" and then releasing to Auto. Doing the same motion a second time will turn on the DRL's again (if in gear), etc.
Hope this helps.
DRL's are on when the low beams are on. I've driven many a mile with a C6 behind me at night, and the DRLs are on(easy to see the amber light next to the white light of the low beams).
I might add that if the car is a manual, the DRL's are turned off if the parking brake is set.
The OEM amber light in the headlight cluster is on with your low beams but it is the dimmer of the two filaments and it's part of the running/parking light circuit.
The brighter filament for the DRL/turn signals is not on.
Go out and start your car and turn on the headlights and watch what happens to the amber light when you use the turn signals.
