DRL switchback users....
Old Dec 28, 2012 | 07:01 PM
vig1116's Avatar
vig1116
Default DRL switchback users....
Are you running the resistors? And if so where did you put them? I was going to mount them in the engine bay but I'm afraid to melt the plastic sidewall, even with the heat tape under it like others have used.... if i go without the resistors is it going to damage the new eagle eye LED tail lights i just installed??? I'm in the middle of the job now and can't decide what to do....
Old Dec 28, 2012 | 11:52 PM
RPA_KNUT's Avatar
RPA_KNUT
2020 C6 of the Year Finalist - Modified
Yes, i have the resistors behind mine, and if i remmeber correctly, they are mounted on the frame member that is directly behind where the headlight housing sits. No ill effects so far on the Eagle Eyes. The whole package proably flashes at a rate 1/2 way between stock and full 'no-resistor' hyperflash.
Hope this helps
Old Dec 29, 2012 | 04:15 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
If you are going to run your car with the lights in the DRL mode, the front load resistors will be "on" constantly and will obviously get very hot.
Mounting them in the engine compartment is a good idea because you will get better air circulation.
The post you referred to that used the aluminum tape to protect the plastic sidewall panel in the engine bay is a good approach.
The one thing you could add to improve cooling is to include washer(s) on the mounting bolts, under the heat-sink to create an air gap between the load resistor/heat-sink and the plastic sidewall/foil tape.
If you can find small fiber washers, as opposed to metal ones, it's even better.
Whatever you decide to do in the front of the car should have no negative effect on your Eagle Eye Tail Lights.
Old Dec 29, 2012 | 09:44 AM
docbaker's Avatar
docbaker
I have to disagree, I just got finished installing these with other projects I have going on in the front of the car. I mounted mine under the headlight buckets since I had the headlights out. The resisters only are working during the flash mode because they are supposed to be connected to the blue/white stripe or (on my car) the green/white wire going to the DRLs. This is the wire that controls the flash. You connect the resister between this wire and the black (ground wire). Since my wheel wells are still apart I can reach up and grab the resisters were I mounted them so just to test this I turned on my DRLs for 10 minutes and the resisters were stone cold. When I turned on the turn singnal they started to get warm but it was over 2 minutes before they were getting warm enough that you didn't want to hold onto them for long.
I hope that helps, good luck.
Old Dec 29, 2012 | 10:56 AM
Knob Jockey
Uh..............no.
The turn signals ARE the DRL's.
If you have correctly connected the load resistors to eliminate the turn signal hyper flash, then if you turn on the DRL's (stalk switch in "Auto" and the car in gear) the load resistors are "on" too.
The connector for the DRL/turn signal lamp has 3 pins. The connector has small letters embossed into it . A, B and G.
A is the DRL/Turn Signal Lamp supply voltage and the wire is blue/white.
B is the Park/Running Lamp supply voltage and the wire is brown
G is the Ground and is black.
The load resistor connects across the blue/white wire and ground, using either the black wire or a chassis ground point.
The left side high beam connector (2 pins, 12V supply voltage and ground) has a dark green/white wire (right side is dark blue/white).
If the resistors are hooked up right, then I'm guessing you turned on the running/parking lamps side of you switchback LED's for your 10 minute test.
Check this recent thread for more clarification.
http://forums.corvetteforum.com/c6-c...post1582680457
Old Dec 29, 2012 | 11:12 AM
BoosterClub's Avatar
BoosterClub
I still can't believe no one knows how to just code the DRLs out.
Old Dec 29, 2012 | 11:22 AM
Knob Jockey
The BCM is a quagmire.
Old Dec 29, 2012 | 11:24 AM
vig1116's Avatar
vig1116
Thanks guys. I finished this last night and went with the resistors and put them in the engine compartment. I put three layers of heat tape under the resistors but never thought of elevating the resistors with washers, I'm going to do that! As far as the heat, I'm guessing by what you guys are saying, that at idle the resistors will be cooler but once in gear the resistor will get hot? I thought docbaker was right cause I did the same thing (checked at idle) and it was cool but when I left the turn signal on it was getting warm. I didn't check it in gear... I just hope it doesn't ruin anything over time, i love the switchbacks and eagle eye tail lights, they go great with the 6k lows and fogs!!
To DRL switchback users....
