Sump pump
Old Dec 29, 2012 | 03:42 PM
logansrun's Avatar
logansrun
Blue on Black
Default Sump pump
Can you put a dry sump in a LS3 08 engine at what cost and benefits?
Old Dec 29, 2012 | 03:50 PM
ErnieN85's Avatar
ErnieN85
yes it can be done, about $5~$7 thousand cheaper if you can do it yourself. only needed for hardcore track duty
Old Dec 29, 2012 | 03:54 PM
logansrun's Avatar
logansrun
Blue on Black
Thanks dont think I need to spend that kind of $ on it.
Old Dec 29, 2012 | 03:59 PM
JoesC5's Avatar
JoesC5
Yes, but it requires a new crankshaft in the engine plus the two stage oil pump, a new pan, oil lines and the reservoir. Then you have the expense of relocating the battery from under the hood to the right side cubby hole in the back.
Only benefit is when running on the track at high G's through a wide sweeping left hand corner.
I've seen plenty of C3's, c4's, C5's and C6's running at 110 to 130 MPH through the wide sweeping left hand corners at Talladega without suffering loss of oil pressure. And they had wet sump systems.
Stock C6 pulling .92g's isn't a problem with the stock wet sump system.
Old Dec 29, 2012 | 05:07 PM
tim414's Avatar
tim414
St. Jude Donor '12
Old Dec 29, 2012 | 05:59 PM
timmyZ06's Avatar
timmyZ06
I thought op wanted some plumbing advices!!
Old Dec 29, 2012 | 09:03 PM
Gary '09 C6's Avatar
Gary '09 C6
^ that's what I thought as well...!
Old Dec 29, 2012 | 09:16 PM
JJPonzini's Avatar
JJPonzini
and I was going to recommend a battery backup system.
To Sump pump
