I'm sure someone here will know what the deal is. When you open the door the window comes down a bit as it should. But some times when you close the door, it's a few minutes before the window will go back to completly closed. And a couple times when it did go back in place it went up and down several times (like it's possessed) before closing. I do know that I need to replace the door handle on this side. The contacts are about wore out. Do those have anything to do with each other? Thanks!
The first thing to do is re-index your windows. It takes 10 seconds per window. Your manual tells how to do it. If that doesn't work it's time to start trouble shooting. Good luck.
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Try re-indexing the windows.
The easiest way is to get in the car, close the door, go to accessory on the start switch. Lower the window all the way, raise the window all the way, release the switch, engage the switch in the up position and count to 5. Release the switch. Repeat for passenger side.
If they still act "possessed" you may have a battery going dead.
In case you don't know how to re-index your windows.
1. Close the door.
2. Raise the window by pulling up the switch.
3. Hold the up switch for three seconds after the
window is closed. Release the switch.
4. Hold the up switch again for three seconds and
release.
Originally Posted by flhden
Sorry Tally Ho we posted at the same time.
No worries. The more info the better. I recently had a friend of mine in PA go through this procedure as I talked him through it over the phone. He is new to the C6 and had disconnected his battery for maintenance and then wondered why the windows would not index.
It's the keypad (door handle) that causes this. $20 for a new one.
If a problem is due to the outside switch the OP can swap the driver and passenger switch pads and the problem should move from one door to the other. A weak battery can cause door issues as well but it usually doesn't result in the window operating own its own.
More than likely it isn't the switch pad. The switch pad provides a ground for the door module which controls the door latch in the B pillar and the window motor. If the door is closed and the window goes down on its own while the door remains latched it is more than likely the switch isn't involved.
When this first happened on my Z the window wouldn't close all the way and I tried reindexing but as the symptoms became worse the window would start cycling up and down on its own and the door wouldn't open using either the inside or outside door buttons. When I took it into the dealer it sat in the service bay with the window going up and down while the repair order was being written up. The only way to open the driver's side door was to use the emergency pulls. A new door module resolved all of the issues.
Bill
Your last paragraph is exactly whats going on. Thanks. Who sells door modules on this site? Thanks.
The two parts can certainly be related...here is the text of a service bulletin...note the "continuous up and down"....
"EI08034 — Power Window/Regulator Concerns, Inoperative, Intermittent, Indexing, Continuous Up and Down (Diagnose Door Handle Switch, Replace if Necessary)Models: 2007-2008 Cadillac XLR2007-2008 Chevrolet Corvette ________________________________________ ____________________________________This bulletin is being updated to end the need for diagnostic information and to provide field fix information. Please discard Corporate Bulletin Number 08-08-64-001 (Section 08 — Body and Accessories).___________________________ _____________ ___________________________________Condi tionSome customers may bring their vehicles into the dealership for a concern relating to the operation of their power windows.CorrectionDiagnose the exterior door handle switch as a possible cause for this condition. If diagnosis confirms the condition is caused by the exterior door handle switch, replace both driver and passenger switches. Be sure to mark which switch comes from the driver and passenger doors. Parts will be requested back through the Warranty Parts Center return process.Parts Information Part Number Description10446243 Front Side Door Handle SwitchWarranty InformationFor vehicles repaired under warranty, use: Labor Operation Description Labor TimeN9588* Front Side Door Handle Switch — Replace (Both) 0.9 hr*This is a unique labor operation for bulletin use only. It will not be published in the Labor Time Guide. "
