Quick easy seat fix mod
Here's the before pic and you can see where the wire is cutting into the foam.
I'm only 175# naked (no pics) and the car has 104K miles, but I suspect drivers of a larger size would have even more damage and probably in less miles. It seemed that something kinda flexible, yet tough enough not to be cut by the wires needed to be inserted. I ended up buying a 13x18 dinner placemat I found at Bed, Bath, & Beyond. It is flexible plastic on one side and backed with a dense foam for a total of 3/32" thick. Just for fun, I picked red to match my car.
I cut it in half, thinking I'd need one on the passenger seat. When I flipped that seat over to inspect for damage, this is what I found. It was now a question of why was it missing on the driver's seat.
Here's the pics after the install of the half placemat.
Pretty simple and cheap cure for the sagging seat problem. The best part was that the barrier is flexible enough that it didn't require any disassembly of the seat to install. I just folded it in half, then slipped it in from the front, and rotated it sideways between the foam and wires. Smaller hands than mine would make it easier.
Last edited by HOXXOH; Oct 23, 2018 at 11:48 AM. Reason: restore pics that PB blocked
It lasted for over 100K miles with very little damage. If the wires finally wear through at 500K miles then GM gets to finally sell another car.
It does seem srange, however that the passeger seat has a barrier and the driver's doesn't. I just checked and mine is the same. I can feel no wear through of the wires at 48K miles but I can't see up in there without removing the seats. I'm not going to worry about it because I'm probably going to sell the car before 500K miles and the new owner can put a barrier in even after the wires wear through. Now if I happen to take the seats out for some other reason...
My plans are to replace the seat foam with a new one and at the same time replace the heater element, cover the seat frame with 2" fuzzy side velcro and keep the seat kit in it.
Both the "kit" and the "place mat" mod here address the issue of the seat foam being sliced by the wires that support it. But neither addresses the issue of the seat foam also being sliced by the razor-like metal seat frame edge. Your fuzzy velcro on the seat seat frame edge should mitigate that issue. You can also glue a small piece of leather or the like directly to the foam in that area to help with seat edge slicing.
IIRC, the passenger seat has the extra material because of the sensor needed to turn on/off the passenger airbag. Something about distributing the load so the sensor notices it correctly.
Here's the before pics and you can see where the wire is cutting into the foam.
The jute pad is used on the passenger seat to give a solid foundation for the Passenger Presence Module which is used to determine when the air bag is turned on or off.
GOOD Solution. On my C5s I used to use Microfibre polishing cloths and they worked very well to keep the springs from cutting the foam.
Bill
Hey thanks for forwarding this post to me JC!. Most will also be shocked to find out that the razor sharp and thin frame side rails will eat into the foam under the exit side bolster, beacuse of the motion of entry and exit. Mine was as such at 6700 miles. This looks like a good solution if you do not want to completely remove the seat cushion and elevating it slightly should reduce the strain and the tearing under the bolsters also. I taped over the sharp sides (after getting a replacement foam cushion under warranty), and used the 2 small foams on the seat rail and the very thin ballistic nylon glued to the underside of the cushion. The other foams and the jute made the seat feel like at least 2 inches higher, I like to sit really down and low. It would probably settle down with time, but it takes me almost 3 months to put 1000 miles on the car so I could not wait. Although I had to rip of the seater heat pad and re-glue it to the new cushion, it works just fine. (however academic in Florida)
As far as the yellow connector, none of the connectors are a problem, I do not tilt the seat all the way on its side like the video, I remove it from the bolts reposition it on the floor and tilt it sligthly and hold it up with my arms where my hands are still free to do the work to disconnect connectors underneath of it. Suggestion however, if you are going to do so, wear a long sleeve shirt. Both of my arms are fairly bruised where it was lifting and supporting the seat as those seat rails are sharp!
