Door switch
Old Jan 12, 2013 | 08:54 PM
RT2SJB's Avatar
RT2SJB
Default Door switch
Two questions how hard is it to replace the door switch (electronic swithc used to open the door)and what forum vendor sells the ones to match the color of my car?
Old Jan 12, 2013 | 09:03 PM
drich2905's Avatar
drich2905
Inside or outside door switch?
Old Jan 12, 2013 | 09:12 PM
vig1116's Avatar
vig1116
easy as pie, and im sure most of them....
http://www.corvettemods.com/C6-Corve...ls_p_6046.html
Old Jan 12, 2013 | 09:23 PM
RT2SJB's Avatar
RT2SJB
Default outside
the outside switch.
Old Jan 12, 2013 | 09:26 PM
vig1116's Avatar
vig1116
Originally Posted by RT2SJB
the outside switch.
easy as pie....
http://www.corvettemods.com/C6-Corve...es_p_5182.html
PS unless it's broken, it's not the electronic switch that you'll replace, just the handle part, it's 2 screws....
Old Jan 12, 2013 | 09:43 PM
RT2SJB's Avatar
RT2SJB
Default swithch
I think it is the switch some times when the swithch is pushed the door does not unlock completly and you have to push is several times befor the door unlocks. Can the switch be lubricated or is it best to replace the switch? Is the switch as easy to replace as the handle?
Old Jan 12, 2013 | 10:00 PM
vig1116's Avatar
vig1116
that im not sure, but im guessing that it shouldn't be hard at all once you take the handle part off (like i said 2 screws). I'm not so sure that it's the switch thats the problem though. If it works sometimes im guessing it might just be a FOB battery, or maybe something as simple as interference with the fob. Is the fob in your pocket with, lets say your phone? I know my iphone interferes with all my fob if they are in the same pocket.... i could be way off thug, good luck
Old Jan 12, 2013 | 11:26 PM
blueyeszr1's Avatar
blueyeszr1
Account suspended by request 6 Oct 2017
Someone here wrote about taking the switch out and cleaning the contacts. Do a search, that might be the problem.
Old Jan 13, 2013 | 12:31 AM
4thC4at60's Avatar
4thC4at60
Can remove, clean, and replace the touch pads in about 15 minutes. After you've done it once you can do it in 10 or less.
Old Jan 13, 2013 | 12:32 AM
VET4LES's Avatar
VET4LES
I've cleaned mine. Just remove and clean them and they will be like new. Very easy to do.
Old Jan 13, 2013 | 12:36 PM
carpe dm's Avatar
carpe dm
Old Jan 13, 2013 | 05:26 PM
cclive's Avatar
cclive
Cleaned and then contacts protected by a light film of WD-40, they will be better than new ones.
Old Jan 13, 2013 | 10:44 PM
Ozarkwoods's Avatar
Ozarkwoods
Easiest task I did on the vette.
Old Jan 14, 2013 | 12:33 AM
CO Lightfoot's Avatar
CO Lightfoot
...how hard is it to replace the door switch...
Looks dead simple... step-by-step photos & instructions:
http://www.theredlion.us/C6%20door%2...itch%20DIY.pdf
Just don't let the disconnected wiring harness drop inside the door.
Instead of replacing the door switch, you can clean the contact pads:
http://forums.corvetteforum.com/c6-c...-pads-too.html
But a new one is only ~$15.
To Door switch
