Caliper color
Old Jan 13, 2013 | 07:34 AM
AV8TOR536's Avatar
AV8TOR536
Default Caliper color
I have a Magnetic red Coupe,whats your opinion on what color I should paint my brake calipers.
I don't think they make caliper paint to match the car do they?
Old Jan 13, 2013 | 08:14 AM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
Black with RED letters.
Old Jan 13, 2013 | 08:43 AM
roscoe118's Avatar
roscoe118
Magnetic Red wasn't offered on the C6, was it? Maybe 2005 only???
Either way, I have a Magnetic Red C5 and painted the calipers with some Cranberry Red Rustoleum door paint from Lowes...
It matches vert well and looks great. I'll try to dig up some pictures that I took when I put it on. I put some chapstick on the raised Corvette lettering, brushed on a few coats, and used an exacto knife to remove the chapstick (could also use a flat sanding block). Its been on for three years and still looks good. You do not need high temp, or special caliper, paint!!!
To do an actual Mag Red color you will need to powder coat them...
Old Jan 13, 2013 | 09:03 AM
drich2905's Avatar
drich2905
here's a couple of photos of crm with powdercoated calipers by Mike.
Maybe it will give you an idea what yours would look like with a body color caliper color
Old Jan 13, 2013 | 09:19 AM
dvilin's Avatar
dvilin
Old Jan 13, 2013 | 09:23 AM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Magnetic Red as available ion the early '05 and then GM switched over to Monterey Red.
I have a Monterey Red and mine are powder coated to match.
You can always get the paint mixed to match if you don't want to go with the powder coated.
Old Jan 13, 2013 | 11:59 AM
Mike Campbell's Avatar
Mike Campbell
I had mine done by Mike the Powdercoated in Monterey Red. I think it is the best way to go....same and car color unless you have a white, black or silver.
Old Jan 13, 2013 | 12:01 PM
Bumpnrun's Avatar
Bumpnrun
Another vote for Mike the PowderCoater..
Old Jan 13, 2013 | 12:40 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
ZR1 Blue works
Old Jan 13, 2013 | 12:52 PM
TOBASCO's Avatar
TOBASCO
CI 2-4-5-6-7-8-10-11-12 Vet
NCM Ambassador
St. Jude Donor '08-'11-'13-'14-'15
You can get any color you want if you get them powder coated. On my C5, I had a Mag Red and had Mag Red calipers done. They looked great. Any other color other than silver or black would look "off" IMHO.
Edit: I was trying to find a close up picture I may have had, and so far haven't found one. Here's one from a bit of a distance - hope it helps.
Old Jan 13, 2013 | 12:55 PM
Kreuzen's Avatar
Kreuzen
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Magnetic red
Old Jan 13, 2013 | 01:44 PM
383vett's Avatar
383vett
Mike the Powdercoater.
Never-Enough's Avatar
Never-Enough
Body color or black
Old Jan 13, 2013 | 01:56 PM
plmkrzy's Avatar
plmkrzy
Originally Posted by Never-Enough
Body color or black
Old Jan 13, 2013 | 01:57 PM
AV8TOR536's Avatar
AV8TOR536
[QUOTE=TOBASCO;1582813037]You can get any color you want if you get them powder coated. On my C5, I had a Mag Red and had Mag Red calipers done. They looked great. Any other color other than silver or black would look "off" IMHO.
Yes, I agree that powder coated calipers look the best BUT..there is no way I am going to spend $425 to do it and then have to bleed all the lines again.
Old Jan 13, 2013 | 02:08 PM
05dsom's Avatar
05dsom
^^nice
Old Jan 13, 2013 | 03:12 PM
HOXXOH's Avatar
HOXXOH
Duplicolor in a rattle can or any spray can that is a real close color match will do fine. $5-10 and a couple hours (mostly cleaning) will do a good job. It's also easy to do a refresh down the road at no additonal cost.
Old Jan 13, 2013 | 05:20 PM
cclive's Avatar
cclive
Do it in paint or powder coating, but do it in mag red...looks great!
To Caliper color
