Shifter
IMO MGW is this the best you can buy.
- Does the shift **** (with the stock one) sit any higher than stock?
- Is there absolutely any extra noise from the lack of insulation the stock one has? And how about vibration?
- And finally, was there any improvement on cold notchines and crunching (if afflicted) when cold? That's mostly a tranny issue, but when adjusting the shift box twice, I had different results, even though the same identical service manual method was used.
I'm quite happy with the stock shifter, but it could be better, especially when cold, and on the notchiness of some gears even when hot. And yes, I already did pretty much everything you can: Amsoil fully-synthetic Troque-Drive fluid, shift detent shimmed with one washer, shift box adjusted, and clutch fluid 'ranger method' done like 15 times in 3K miles (since day 1). Don't want to install an MGW if it's going to allow any more noise inside the cabin. Car is already noisy enough
. Thx.
MGW is just such a well put together shifter that is smooth, and very high quality. It is not so smooth that it doesn't have feel though. Very positive shifts.
. Thx.I would recommend the insulation kit that mgw sells on their website for like 10 bucks to make it even quiter than stock.
