Front end alignment check??
Old Jan 27, 2013 | 03:56 PM
p4snow's Avatar
p4snow
Just broke 2,800 mlles on my 3 month old C-6 coupe. Hit a pot hole the other day, but car shows no signs of pulling in either direction - right front hit the pot hole. How can I tell if an alignment is needed?
Old Jan 27, 2013 | 04:10 PM
carpe dm's Avatar
carpe dm
Originally Posted by lebvette
Do it.....you probably will save yourself two to four tires.
Have the Dealer tech set the camber and toe to as close to 0 as he can get.
Old Jan 27, 2013 | 04:46 PM
cclive's Avatar
cclive
A bad alignment that can destroy a tire is not necessarily something you can feel in the steering wheel. Inspection on an alignment machine is the only way to tell for sure...except for the long term solution which is to wait and see if a tire gets ruined...then you will know, a little late alas.
