door panel tools
Old Jan 26, 2013 | 06:02 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Default door panel tools
I'm going to be changing the speakers in my doors sometime soon and was looking at tools for popping the panel clips. I see this 4 piece tool set, they are made of plastic and range from $8 - $12. Has anyone used this type and do they work? I do not want to spend money on steel ones to just use once and then keep moving them around the tool box because they are always in the way. lol. They are on all the major parts store web sites and even on ebay.
Old Jan 26, 2013 | 06:21 PM
fastter's Avatar
fastter
Worked for me. The plastic was just fine. Use in conjunction with an old credit card and some blue tape to protect surfaces and you'll be just fine.
Old Jan 26, 2013 | 06:41 PM
chimazo's Avatar
chimazo
I've used this tool more than I imagined, for various cars/projects over the years. Quite handy!
Old Jan 26, 2013 | 06:48 PM
ls1121's Avatar
ls1121
is this home made? because I think I can make one like it.
Old Jan 26, 2013 | 06:50 PM
ls1121's Avatar
ls1121
OK thanx.
Old Jan 26, 2013 | 07:39 PM
chimazo's Avatar
chimazo
http://buy1.snapon.com/catalog/item....roup_ID=681556
Well worth the $16.
Old Jan 26, 2013 | 08:19 PM
Tide Will Roll!'s Avatar
Tide Will Roll!
I should have bought one of those but forgot to get it....
So when my speakers arrived I said WTH and went for it without a tool.
At the bottom of the door panels near center is a notch about the size of your four finger tips. Just tug there and it will pop out, once you get it started...no problem.
BTW there are several how to threads with pics that show step by step how to remove/replace the panels and upgrade speakers.
If you dont find, let me know. I will find you the link.
Bert
Roll Tide
Old Jan 26, 2013 | 08:26 PM
ls1121's Avatar
ls1121
Bert
Roll Tide
Cool thanx. I normally just rip the door panels off of my Z28 but I want to be a little more Gentle with the Vette.
Old Jan 26, 2013 | 08:53 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
I bought a very inexpensive set of plastic pry-tools from Harbor Freight.
Sears has them too.
Worked well.
Old Jan 26, 2013 | 09:47 PM
Tide Will Roll!
Be sure and search out the DIY thread. There is a trick you can use to reinstall where you use a shoestring to make it easier
Bert
Roll Tide!
Old Jan 26, 2013 | 10:12 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
Sears has them too.
Worked well.
I have a cheap plastic set that works great.
Old Jan 27, 2013 | 12:44 AM
Keppler's Avatar
Keppler
St. Jude Donor '25-'26
Buy new pins and sockets because you will break a few pins removing the panels. Do not buy them from GM. Buy them here: http://www.clipsandfasteners.com/Sea...x=0&Search.y=0
Old Jan 27, 2013 | 10:19 AM
ls1121's Avatar
ls1121
Rock'n'Roll thanx guy's.
Old Jan 27, 2013 | 11:40 AM
j_digi454's Avatar
j_digi454
Worked well.
I also used them to change my gauge cluster and console bezel and other interior parts that i changed.
Old Jan 27, 2013 | 09:21 PM
ls1121's Avatar
ls1121
went to Harbor Freight....$6.99 5 piece set what a deal thanks for the heads up. Now as soon as my speakers get here the sound quality will improve.
To door panel tools
