427 vs Z06 Questions
Although I think the C7 is going to be a great car, I'm thinking I will stick with a C6 when my lease is up in about 3.5 years. I'm thinking of going with a used 2012-2013 Z06 or a 427 next time, and although that purchase is a long way off I still enjoy the research.
I would prefer the handling of the Z06, but I don't believe I can live with not having an open air car in the summer. I know the 427 uses a GS convertible steel frame, and therefore weighs more than the Z06, but I have some more questions.
1. How much more does a 427 weigh over a Z06?
2. What suspension components does the 427 use? Do the shocks/springs/sway bars match the GS specs more than a Z06?
3. Are other parts just as durable and race ready as the Z06 such as the rear end and transmission? (do they use the same transmission and gear ratios?)
4. Has anyone tracked a 427 and if so how was the experience?
5. Can you get a 427 with the carbon pieces and ceramic breaks? If not would it be possible to easily add the ceramic breaks after market?
Thanks in advance for any help.
From what I can tell from the web site. You can get a carbon fiber hood, but the "carbon fiber package" only adds carbon fiber pieces and does not replace any existing ones.
It also lists a magnetic selective ride control option, but it does not mention anything about PTM or the other performance features of the magnetic shocks that are available with the Z06. Which makes me believe it is the shock setup that is available on the base coupe and not meant for the track.
Location: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
Received 1,484 Likes
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
The hood and the front fenders are CF. There's also CF in the flooring. The weight difference between a Z06 and a 427 is about 160lbs (427 heavier). The brakes are the same as the Z06 and GS, you cannot order the ZR1's ceramics. I'd have to verify the trans and diff. I have not tracked mine so I can't tell you how it would act.
If you were to select the MSRC option would the springs and sway bars be different?
Do the MSRC shocks on the 427 and non Z07 equipped Z06 handle as well during aggressive driving as the stock suspension package?
The Firebird is not on lease. I have a 2012 Corvette Coupe... the one in my avatar... next to the Firebird.
The curb weight... I'll give you that one. It's listed on the website, so maybe I should not have included that one. But as for the suspension details... that's not so easy to find. For instance even after a few posts I still don't know if you select the MSCR shocks if they also replace other components like springs and sways with that option. For some reason GM usually does not make that type of information well known. I would also like to know how they handle when driven aggressively and how close they are to the Z06.
Sure my potential purchase is not anytime soon, but it's a Sunday, I have some extra time, and to be honest even if I keep my current Corvette forever, I would still be interested in knowing the answer to these questions, as I'm sure a lot of corvette enthusiasts would be.
It's the same reason I enjoy learning about the ZR-1 even though I will probably never purchase one.
tlr, I think a few CF members have posted the specification comparisons of the F & R anti-sway bars & springs
for all the C6 models. Maybe searching more specifically will turn up those threads/posts, and at least answer
part of your question.
Received 8,977 Likes
I own a 427 Convertable and have asked these same questions in other threads. FWIW, the 427 does not share the PTM with the Z06, but from what I have learned, all the rest of the drive train and suspension components are same as the Z06. The magnetic ride control allows a tour mode, a sport mode and you can turn things off and use competition mode if desired. The touring mode is very compliant for street driving and the sport mode really keeps the car flat when driving more aggressive. The convertable is listed as about 160 pounds more than the Z06. There won't be many, if any, driving day experiences as there are no performance driving organizations that will allow a convertable without an appropriate roll bar. I won't be adding one to mine. As to the brake question, since the brakes are the big brakes which are standard on the Z06, I can't imagine that the ceramic brakes couldn't be added later. I do not believe they are an option on a new unit.
Bill
I believe there are a couple members who own both, but again, the 427 would be the "waxer" while the Z06 or the ZR1 would be the "performer".
I guess that would be true. Chevrolet seems to be marketing them as collector cars, and I bet they attract the type of buyer who would keep it in a garage and drive it on the weekends... or not at all if they believe it is an investment. Which it may very well be if GM never produces another 7.0 or greater convertible. Only time will tell.
From what I've gathered so far is it basically a Grand Sport with Z06 suspension and the LS7, with the option of getting carbon fiber.... Which is not a bad thing. If you could take it on a track I'm sure it would place somewhere between a Grand Sport and Z06, how close to either or... I guess we will never know
Although I think it would have been bad *** if they offered it with the ceramic breaks and performance magnetic shocks like on the ZR1. It's a shame they didn't. I bed GM could have charged a fortune for them in limited production.
tlr3715; You keep talking "Track Performance", IT'S A CONVERTIBLE!
You can't track it, all you can do is brag about the options.
BTW, it's BRAKES not breaks.
Moot point. In 3.5 years, you won't want to even look at a C6 unless you don't have enough money to buy the C7.
Same goes for right now. Most people buying a C5 are buying it because they don't want to spend the cash on a C6. Newer models always look better, perform better and feel newer.
Between those two choices I would go for the 427. For all the reasons and differences mentioned above. It is a roadster! Got to enjoy top down touring in that car.
If you want the fastest and to track a car then select the Z06. GM gave a us choices for a reason. We can all be happy. Pick the one that works best for you.
Great Point 67 vs 68 price not even close. So i would say 427 vert because of one year and one year only. I actually have a 2007 Z06 and am picking up a new 60th anniversary edition at the end of Feb. Probably keep the z06 for 3-4 more years until they come out with a C7 ground- pounder. The 60th 427 vert will stay in the stable.
