Adding NPP; The Electronics....
Thanks in advance!
You will still need an aftermarket controller in order to operate the vacuum solenoid though.
Our Exhaust Commander Elite is a great choice because it has 3 operational modes.
1:Loud Mode
2:Quiet Mode
3: User RPM opening mode
So you can have a factory style operation with rpm opening, as well as the stealth quiet mode and loud mode.
Here is the thread for the controller:
http://forums.corvetteforum.com/c6-z...ck-button.html
Video of it in action:
If you need additional info, feel free to let us know.
Ben
It is very expensive to buy all the Oem stuff though. IIRC it was about $600 for all the lines, vacuum ball, and vacuum solenoid. And that doesn't include a way to control them.
Our Exhaust Commander Elite uses the door lock button on the door panel inside the car, and the cars keyfob remote when outside the car to control the system.
We also have the Exhaust Commander D.A.S.H. that uses the DIC reset button. It does not have RPM opening though. Just Loud or Quiet modes.
If you watch the video above it shows how everything works on the Exhaust Commander Elite.
We do have a sale on our Exhaust Commander Elite controllers. You would use coupon code "elite20" at checkout and get 20% off.
We two kits available.
One would be used if you have all the factory lines and solenoid. It is just the electronic controller.
The other is a retrofit kit which includes vacuum lines and a vacuum solenoid, and the controller.
Exhaust Commander Elite All-in-1 NPP retrofit kit
