DIC problem
Is this a new symptom occurring that has worked in the past?
the reprogramming thread if you want it is,.....
http://forums.corvetteforum.com/c6-c...tructions.html
fyi.. i think this came from a user manual..
OPTIONS UNAVAILABLE: This message is displayed
for a few seconds if a keyless access transmitter
that is not labelled 1 or 2 is used and you try to
personalize the features on your vehicle by pressing the
OPTION button. The personalization system will not
recognize the transmitter and the DIC will not display the
current driver number or the menus used to set
personalizations. The personalization features will then
be set to the default states. See DIC Vehicle
Personalization on page 3-67 for more information.
p.s. i also agree that whats stamped on the fob is for your use only. the order they are programmed is the number the car knows them as. so the note of'labelled 1 or 2' really should be... programmed as 1 or 2
i'm mentioning just in case a Canadian version reads this. not sure about europe version.
You will need to use the long programming method to reset them to 1 and 2.
Here is a nice guide on how to do it. Take note not to have any fobs near the car when starting the process.
It sounds scarier than it is. It just takes time. Make sure you have at least 0.5 hour before you start as you have several 10minute countdowns in the process. Good luck.
