DIC Screen Blank
Old Feb 11, 2013 | 09:47 PM
ray418's Avatar
ray418
8th Gear
Default DIC Screen Blank
My 2008 C6 DIC screen went blank (nothing even when first started) when the weather turned cold. Its done this before but when the car warms up it has come back. This time it has stayed off. Anybody else has a problem like this? Thanks
Old Feb 11, 2013 | 11:57 PM
ChevyDave's Avatar
ChevyDave
blank NAV is one thing. blank DIC is another.
i have located 3 folks that had the blank DIC and in all 3 cases , no resolution was stated. your the 4th.
my only clue , which is the discussion of another with the problem, is the bcm connection(s).
in the passenger kick panel under the carpet, possible bad connection(s)????????????
if you resolve the issue , be sure to post it.
fyi... i did a google search on all other model cars and well, they never said what they did either.... lol which sorta tells ya they took it to a dealer.
Old Feb 12, 2013 | 12:05 AM
C6Whatever's Avatar
C6Whatever
Old Feb 12, 2013 | 12:09 AM
4SUMERZ's Avatar
4SUMERZ
Dave, Your right. I just saw blank and automatically assumed NAV screen..my bad! Thanks, and post deleted as to not confuse the subject.
Old Feb 12, 2013 | 05:52 PM
ray418's Avatar
ray418
8th Gear
Thanks I will check the connections and let you know if it works.
Old Feb 28, 2013 | 08:10 PM
ray418's Avatar
ray418
8th Gear
checked fuses all were good
I cannot find any loose connections either
Old Feb 28, 2013 | 08:17 PM
Mad*Max's Avatar
Mad*Max
Old Feb 28, 2013 | 08:23 PM
VET4LES's Avatar
VET4LES
Originally Posted by Mad*Max
To DIC Screen Blank
