Been about 20 years since I've driven a stick. Thinking of getting a GS with a stick in it.
Question is just how long does a clutch last under normal driving conditions?
Define "normal". Normal driving conditions for someone who doesn't race the car and knows how to shift with a clutch will be years and many, many thousands of miles. Normal for someone who hasn't driven a stick in twenty years and doesn't know when to let off the clutch could be three months with a lot of hard launches.
I doubt that it will take me long to get the feel of driving a stick again.
But thanks for the info.
I think you'll be fine, and probably quite surprised at how little effort and how light the feel of the clutch is in new cars. Driven "normally" you should easily get 100K miles unless you're in the city all day.
Some people have had issues with the clutch pedal if the hydraulic fluid gets contaminated, but that is an easy item to take care of.
Just remember these 3 things, and clutch should last you for a long time:
1. Launch with as little revs as possible.
2. Release clutch as soon as possible without being jerky. Crawl with the clutch out in traffic, even if some get ahead of you. Avoiding the friction zone dramatically extends clutch life.
3. Only touch clutch pedal and gearshift lever to shift. Left foot on the dead pedal except when shifting. That will insure you don't inadvertently ride the clutch (the throwout bearing, really) without noticing it.
Good luck, and you're making the right choice. It's infinitely more fun to drive this car in a manual IMO, but for practical purposes, it'll be slower than automatic (if you don't want to abuse your clutch, like most of us). Good luck.
As inferred above, remember to keep the clutch fluid clean. Look-up the "ranger method" for refreshing the clutch fluid.
The fluid tends to turn a dark color quickly due to clutch dust getting past the seal in the slave cylinder. GM has been
routinely criticized on this weak-point of the clutch system design.
I'm out on the forum several times a week, and I cannot recall of any serious clutch issues, that were not self inflicted by heavy abuse of some sort.
I'm sure I missed a post or two, but other than the fluid getting dirty (and it is very easy to flush, I do mine every oil change, it takes less than 10 minutes), the clutch is not discussed out here hardly at all.
With the torque these cars have, you can literally let the clutch out slowly in first gear, without giving it any gas.
My new 1977 Toyota Celica 1st clutch lasted about 50K miles. Hey...Japan and I was learning.
For my new 1983 Porsche 944:
1st Clutch lasted about 100K miles.
2nd Clutch lasted forever. The car was eventually scrapped after 23 years, and 550K miles. The second clutch was still GOOD after 430K miles.
A Porsche technical director who lived near me, mentioned that if you drive the clutch correctly, it will last the life of the car. I proved he was correct.
My replacment Porsche 944 with auto transmission, the transmission lasted 200K miles...and the replacement was just trouble.
So to me, a manual transmission is MUCH MORE reliable. And my gas mileage jumped about 30%.
And now my new gorgous Yellow C6 with manual and 90K miles so far...well here's to forever.
