HELP Passenger Window Stuck
Old Feb 17, 2013 | 12:18 PM
jensencl's Avatar
jensencl
Default HELP Passenger Window Stuck
I have looked around and found similar problems, but not exactly the same. My pass window is all the way down. It will go up about 1" and it will even index down this low.
So what happened?:
I changed the door speakers in both the driver and pass doors. The drivers door had this same problem, but righted itself after re-indexing the window. The passenger window will not share this sentiment though.
What I've tried:
I have tried re-indexing the window, pulled the door woofer out to see if anything it restricting it, disconnected the battery for about 30 minutes. None of these attempts have yielded any sort of light at the end of the tunnel.
I'm sure there is just something I am missing and I hope someone can point me in the right direction. It seems like the window thinks it has rolled all the way up after it has moved ~1".
Thanks in advance for reading and hopefully making suggestions.
-Chris
(Sorry, I forgot to mention, this is a 2008 C6, 1LT)
Old Feb 17, 2013 | 12:32 PM
ChevyDave's Avatar
ChevyDave
hummm... if you had said that it goes up only half way before stopping... i'd have said that you didnt have the door closed, because it has to be closed the first time you re-index or it just stops half way up for saftey purposes.
but 1" hummm
Old Feb 17, 2013 | 12:50 PM
jensencl's Avatar
jensencl
Its a totally messed up conundrum right? I haven't seen a problem like this yet. I am tempted to make a video and supply a link to make sure I am describing it right.
Old Feb 17, 2013 | 12:52 PM
wayback's Avatar
wayback
wonder if the window jumped off the bottom track. That has happened to me in another car.
Can you hear the motor working for the same amount of time as the good one?
Old Feb 17, 2013 | 12:54 PM
jensencl's Avatar
jensencl
wayback, No, it only works for the length of time that it moves. It's just like it hit the "end of movement switch". (sorry forgot the proper name)
Old Feb 17, 2013 | 12:58 PM
wayback's Avatar
wayback
Try pulling up on the window as you use the button to raise it. Might be jambed a little and shuting down due to excessive force.
Old Feb 17, 2013 | 01:06 PM
ChevyDave's Avatar
ChevyDave
another free fix-it to try.
hold the UP button (with door closed) for at least 30 seconds.
Old Feb 17, 2013 | 01:09 PM
jensencl's Avatar
jensencl
ChevyDave, Have not heard 30 seconds. I am going to go give that a try right now. Does it matter if I use the driver or passenger window control? Does something with the window system reset when the door panels are unplugged or something?
Old Feb 17, 2013 | 01:10 PM
wayback's Avatar
wayback
use drivers side.
Old Feb 17, 2013 | 01:12 PM
jensencl's Avatar
jensencl
will do. on my way. I'll get back to you in a few minutes.
Old Feb 17, 2013 | 01:16 PM
jensencl's Avatar
jensencl
30 seconds, no luck. This is a never ending dilemma.
Old Feb 17, 2013 | 01:20 PM
ChevyDave's Avatar
ChevyDave
well, i went through all the search for your problem. other that one person saying that they held it for more than 10 seconds and it suddenly went zip up... or and others that had wiring hangup stuff, causing problems , no idea.
when the window feels it has hit a stop, it will stop. and remember where it stopped.
i'd do this then i have no ideas.
disconnect battery again. wait a few mintes. then try reindex again
added... oh , reread your post, you already tried disconnect/reconnect/reindex. sorry , i ran outa ideas
Old Feb 17, 2013 | 01:23 PM
jensencl's Avatar
jensencl
Will do. Thanks for all the help guys.
Old Feb 17, 2013 | 04:24 PM
jensencl's Avatar
jensencl
Dave,
Tried a new approach. Disconnect door panel, disconnect battery (1 hour, had lunch and such), reconnect battery, THEN reconnect door panel, reindex window; and viola, works like a champ now. Had to have the right sequence I suppose. Thanks again for all the help.
To HELP Passenger Window Stuck
