What cabin filter do you use?
Old Feb 26, 2013 | 07:10 PM
Red08's Avatar
Red08
Default What cabin filter do you use?
I replaced the cabin filter last fall with one from NAPA before I put it to bed for the winter. It was the correct filter, but seemed a little difficult to insert the new filter... a tight fit. I bought the car used with about 23,000 miles, and I couldn't believe the amount of dirt and crap that was trapped by the old filter. I am glad I changed it.
Old Feb 26, 2013 | 07:17 PM
Jmelz's Avatar
Jmelz
I got one from advance, and had the same issue. It seemed as though it wanted to bunch up as I slid it in, because it seemed too wide (wide in the distance from passenger side to driver side. As I slid it in, it didn't seem to want to push all the way to the back as it should.
Old Feb 26, 2013 | 07:35 PM
Red08's Avatar
Red08
Yea, that's exactly what mine did. I took a wooden ruler and tried to push the back of it all the way to make sure there wasn't an "unfiltered" space between the back of the filter and the filter housing.
Old Feb 26, 2013 | 07:43 PM
vig1116's Avatar
vig1116
i use oem charcoal, no problems....
Old Feb 27, 2013 | 12:09 AM
CO Lightfoot's Avatar
CO Lightfoot
Great fit in my 09 C6 with the Purolator cabin air filter p/n C25623C (C version is carbon-impregnated). Only $12 at Advance Auto 2 years ago.
But the non-carbon filter I got from NAPA 4 years ago was a very tight fit. Scraped-knuckles pain-in-the-a$$.
They looked the same size to my old eyes. Go figure.
Old Feb 27, 2013 | 12:25 AM
BLU JET 07's Avatar
BLU JET 07
I stayed with the AC Delco that came with it from the factory. Might be a little pricey @ $34, but I only change it once a year when I do the CAI filter.....
Old Feb 27, 2013 | 01:49 AM
OKJefe's Avatar
OKJefe
I replaced mine with a WIX and had the same issue with busted knuckles. I planned to switch to a different one next year and will try the AC Delco after reading this. Great thread.
Old Feb 27, 2013 | 02:13 AM
LS WON's Avatar
LS WON
Just make sure you know which way the arrow faces.
Old Feb 27, 2013 | 06:22 AM
Don-Vette's Avatar
Don-Vette
This is the one I use....
Factory one is laying on bench,Purolator has charcoal..
Old Feb 27, 2013 | 06:34 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Purolator. Fits much better, has charcoal, costs less.
Old Feb 27, 2013 | 06:59 AM
CCIE's Avatar
CCIE
Surprised it needs to be replaced annually. ??? Happy to do so if needed, just surprised.
speedraider's Avatar
speedraider
Purolator ...
Old Feb 27, 2013 | 08:31 AM
Don 79 TA's Avatar
Don 79 TA
i used a WIX one in the wifes 05, but she still claims about certain smells
so i just bought an OEM one
the charcoal type will filter out other smells too
so we shall see
Old Feb 27, 2013 | 08:57 AM
CO Lightfoot
Annually? Maybe not. Depends how often you use the system.
Old Feb 27, 2013 | 10:05 AM
krazy1's Avatar
krazy1
Purolator c25624c is $34.00. If GM filter is the same price, I will use the Purolator.
Old Feb 27, 2013 | 10:17 AM
LEAVINU's Avatar
LEAVINU
Old Feb 27, 2013 | 10:40 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Originally Posted by LEAVINU
To What cabin filter do you use?
Old Feb 27, 2013 | 03:44 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I use the GM charcoal version, purchased from a CF vendor for best price.
The slot that the filter fits into, is slightly curved (ski slope), higher at the front than at the rear. Probably so you don't need to remove the battery to change filter. Makes it tougher to install the filter, but using two dowels or rulers helps.
Most filters have an arrow indicating which way the air flow should go, in the C6 you want the arrow pointing down because the air enters at the top and exits at the bottom.
Old Feb 27, 2013 | 04:02 PM
j_digi454's Avatar
j_digi454
Same one I use, it was $11 minus a $3 rebate. Fit perfectly, no issues installing it.
This is not the right part number for the Vette, you sure your buying the correct filter? Also Part No. C25623C is not $34, as mentioned, it's more like $12.
Old Feb 27, 2013 | 04:19 PM
BLK08C6's Avatar
BLK08C6
Just replaced mine with a Wix 30 minutes ago. It didn't seem to fit until I realized after looking in the slot that there is a guide that directs the filter upward the farther it goes in then it went in just fine. It slides in at an upward angle, so if one isn't careful it will bunch up and could be ruined. Slow and easy
