knocking sound
Service rep said he went out to a 427 and it did the same thing.
Hmmm, not sure if I buy that.
I'm going to ask about it at one of the technical sessions at the Bash later this month.
Get a second opinion.
The usual setup consists of an air door that's actuated by a bell crank at the end of a little plastic gearbox driven by a stepper motor.
One of the plastic gears inside the box strips and makes that sound. The HVAC control unit cycles the motor repeatedly trying to get the door to swing.
I'm annoyed they brushed it off so quickly as normal.
FWIW, my 2013 GS does not have the noise.
If I'm wrong I'd be glad to hear it. But after driving around for about a year with that clacking sound, mine got worse and I just paid for it to be done about three months ago.
Good luck.
After I was told the clicking noise was normal, I learned to live with it, because it didn't bother me that much.
That was back in April.
Since then I did find out that when it was in bi-level mode, even with the fan on its highest setting, little or no air would come out of the dash vents. It was coming out of the defrost vents.
A-ha!
Something concrete I could show them.
So this morning I take it in for it's 10,000 service.
I show them this.
They call me back and let me know their diagnosis.
Blend mode actuator.
Hmmm, the EXACT thing I told them it was 5 months ago.
They are working on replacing it as we speak.
So...long post short...OP, that's what the problem is.
Driving to work this morning, I hear the ticking again.
So I switch it to bi-level to check the airflow.
Fan on highest setting.
Some air is coming through the dash vents, but not as much as I would have thought.
I know it is splitting the flow between floor and dash in this mode, but I thought there'd be more.
Oh well.
I'll have them check it again at my next oil change.
Added bonus...now my seat rocks. Not sure what they did to get that started. OY.
Tick tock tick tock tick tock.
I will be taking it back for the 4th time to address this.
1st time: "it's normal"
2nd time:"that's not right...replaced blend door actuator"
3rd time: after the ticking came back..."it's normal"
This time the sound is coming from behind the passenger side dash.
Maybe there's another actuator on that side.
I can make it do it by fiddling with the passenger climate controls.
I emailed the assembly plant via their website but never heard back.
Didn't really expect to.
They are probably so deep in C7 now that they don't really care about C6 issues anymore.
Other than this, and the rocking/popping seat, I absolutely love my car.
These are my only two complaints.
Cheers,
JB
I've got a 13 GS with the same issue but mine has had the blend doors and the actuators replaced. Mine also makes the noise when the car is not running and the FOB is not in my pocket. I can hear it hours after parking the car.
