axle ratio
Old 03-08-2013, 01:38 AM
mcslim
mcslim's Avatar
Default axle ratio
Can any any one tell me the gear ratio in my '09 LS3 with A6 paddleshift? It is turning 1650rpms @70mph with stock tire size. Do all auto trans have the same rear axles and are they different manuals? Also, does any one know the difference in individual transmition ratios spread of 6speed autos vs manuals?
Old 03-08-2013, 01:48 AM
Rathmullan
Rathmullan's Avatar
2.56 unless it has the Z51 performance package in which case it would be a 2.73. So no, all C6 automatics do not have the same rear axle ratio. The GS, which comes standard with the Z16 performance package and which replaced the Z51 package beginning in 2010 also has a 2.73 axle ratio when equipped with automatic.
All C6s equipped with manual transmission have 3.42 rear axle ratios.
Old 03-08-2013, 02:28 AM
TerryL
TerryL's Avatar
St. Jude Donor '17
Are all years the same? What's the ratio in my 06 auto vert? Would the VIN tell me?
Old 03-08-2013, 05:48 AM
Turbo6TA
Turbo6TA's Avatar
Received 3,095 Likes on 2,079 Posts
2021 C6 of the Year Finalist - Modified
C6 Ratios
Old 03-08-2013, 07:52 AM
roscoe118
roscoe118's Avatar
Originally Posted by Turbo6TA
C6 Ratios
Thanks... I guess the dynos somehow adjust for the 1.15 gear ratio, of the A6's, in 4th???
Old 03-08-2013, 08:38 AM
SouthBaySurfer
SouthBaySurfer's Avatar
As stated above, 2.56 ratio, or 2.73 if it's a Z51. However, in '08 and '09, the 2.73 ratio was free-standing option on the base car. Check your RPO sticker; code for a 2.73 rear is GU2. I have one in my '08.
Old 03-08-2013, 09:37 AM
pahlbfishn
pahlbfishn's Avatar
I have a base c6 with the 256 and at 70mph my rpms are 1500.
Old 03-08-2013, 09:50 AM
Vette_DD
Support Corvetteforum!
Vette_DD's Avatar
Received 1,278 Likes on 936 Posts
According to this chart, if your tranny is turning 1650 RPM at 70 MPH, your rear axle ratio is 2.73.
http://mysite.verizon.net/foofoo2/c6/A6-2.73.html
Old 03-08-2013, 10:09 AM
Vette_DD
Vette_DD's Avatar
C6 Ratios
Not quite. The chart above has the 2.73 gear ratio left out of it for the "Base" A6s. The chart below is more accurate.
Old 03-08-2013, 01:58 PM
peter pan
Life Time NCM #2196
peter pan's Avatar
Received 1,101 Likes on 812 Posts
That is what my coupe turns and 09 was the last year you could order 2.73 with a non Z51 vette, I know we did this
To axle ratio
Quick Reply: axle ratio
