Issue the outside temp reading
Mar 9, 2013 | 10:49 AM
The temp reading on the screen below the radio is stuck at 75 degrees, no matter what the outside temp is. I have a 2005 C6 base. Anyone have any idea why it's frozen at 75?
Mar 9, 2013 | 11:15 AM
Either the sensor is failed, broken or isn't making good connection with the harness. Sensor is located low on passenger side behind the front bumper.
Bill
Mar 9, 2013 | 11:23 AM
Bill nailed it, its a default value for 'i cant get a signal'.
you can try this........
Value is reset when... the Front Defrost, Rear Defog and fan up buttons are pressed simultaneously.
(but of course , if its unplugged , reset wont help)
Mar 9, 2013 | 12:06 PM
Have you given it time to change? It is designed to lag temperature changes and not be real time when you start the car.
Mar 9, 2013 | 12:08 PM
Quote:
Originally Posted by
ChevyDave
Mar 9, 2013 | 12:55 PM
Thanks for the info. Must be the sensor. I had the bumper off for painting. Body shop must have not re attached the sensor. Will try the button reset first
Mar 9, 2013 | 01:35 PM
If you had the bumper off, that certainly explains it.
Mar 9, 2013 | 06:26 PM
Deceptikon
just curious - I that when it got stuck at 75?
