Turn on DIC display
Mar 10, 2013 | 01:47 PM
Turn on DIC display
Just bought a '13 1LT and want to turn on the DIC display without starting the engine. Looked in the owners manual but couldn't find any info. Tried forum info suggesting pushing start button without pushing on the brake pedal but the diplay told me to press brake. Pushing the accessory button only turns on the radio.
Any suggestions will be appreciated.
Mar 10, 2013 | 01:48 PM
try pressing accessory and hold for 10-15 seconds
Quote:
Originally Posted by
mickey5
just press the accessory button without pressing the brake pedal but you need to keep the accessory button pressed for about ten seconds to go into ignition mode
Mar 10, 2013 | 01:49 PM
Push the bottom of your engine switch (as though you're going to accessory mode) and HOLD for 10-15 seconds; it will go to "Run" mode without actually starting the engine.
Mar 10, 2013 | 01:50 PM
Look at that - three identical responses in less than a minute!
Mar 10, 2013 | 01:52 PM
mpuzach
yea.. and we probably are all wrong.. lol j/k
(we hit it outa the park)
Agree with the above but would add if you stay in this mode for any length of time try and be hooked up to a battery maintainer while doing this.
Mar 10, 2013 | 01:56 PM
FlyerVette
this is good advice because I have had to get a boost a couple of times because I did this while detailing the car (to listen to music)
Mar 10, 2013 | 01:57 PM
Thanks folks, it worked!!
Battery maintainer is on.
Mar 10, 2013 | 06:09 PM
Mar 10, 2013 | 06:14 PM
If it's just to get the odometer reading, try the parking lights.
Mar 11, 2013 | 08:43 AM
butchn
One question, why?
I wanted to spend some time personalizing the "options" while reading about them in the owners manual. I also saw on this forum to look at the voltage readings with engine off when diagnosing electrical problems.
By the way, I'll bite...how do you check the odometer with the parking lights?
If you folks have any other tidbits of "howto" info that aren't in the C6 manual I'd appreciate them.
Thanks again for the help.
Mar 11, 2013 | 09:30 AM
odometer reading..
the first time i saw the service department reach into the open window of my car, do something to the blinker stalk.. odo popped up on dic.
i thought ok, i'm gonna figure that one out.. lol
you turn the light part one click and odo will come up
Mar 11, 2013 | 03:48 PM
mickey5
...If you folks have any other tidbits of "howto" info that aren't in the C6 manual I'd appreciate them.
If you ever lock your fob in the trunk/hatch "dead zone", you'll be glad to have a spare metal key.
Under $10 at most key shops. Tell 'em to use key blank B-106 (same as a Saturn). Be sure to try the key, make sure it actually works.
Lots of
Secrets of the C6 in this old thread:
http://forums.corvetteforum.com/c6-c...of-the-c6.html
And congrats on your new C6!
Mar 12, 2013 | 08:48 AM
Thanks for the thread info and the thumbs up. The key sounds like cheap insurance, I'll do that.
Increased my driving experience enjoyment yesterday...found a person locally that had a transparent roof for sale. It changes the whole perspective.
Mar 12, 2013 | 06:23 PM
I think that when personalizing the DIC it's a good idea to do it while the engine is running. That might minimize battery drain.
Mar 12, 2013 | 09:46 PM
ChevyDave
odometer reading..
Attachment 47720466
Will my learning never cease?
