Performance drop ?
Old Mar 22, 2013 | 06:56 AM
Patsgarage's Avatar
Patsgarage
Default Performance drop ?
O.K. here is one for all you higher mielage guys out there. Have you noticed and drop off in performance at 100k, 150k etc ? I have a long way to go, with only 3k on the new GS (winter stinks) but was wondering how long these engines can go before their age can be felt.
Old Mar 22, 2013 | 07:01 AM
Easy Rhino's Avatar
Easy Rhino
From: Middle TN by way of KY, OH, VA, IL, CA, FL, NY, SC, HI
No drop felt as of 77K miles in mine.
I'm thinking you would have to have some significant degradation, e.g.; clogged fuel injectors, ignition wire dielectric strength breaking down, severe piston ring wear, before starting to feel any real noticeable drop by seat of the pants.
By dyno over time would be interesting, but have not read where anybody has done this.
Old Mar 22, 2013 | 07:32 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Over 40k on my 18 mo old '11. I chunked the OE air filter at 30k and ran 1 can of Chevron fuel system cleaner through it. That's it. Car pulls and feels stronger than when new. I'll change the plugs at 75k. Just buy good gas is all I can suggest and do the required maintenance.
Old Mar 22, 2013 | 07:47 AM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
Almost 70K and drives better than ever.
Old Mar 22, 2013 | 08:01 AM
indyDan's Avatar
indyDan
After working on aircraft engines, I can say that it takes considerable compression loss before it shows up in horse power. I agree with the others that in most cases a performance drop would be due to injectors or tuning before anything else. Detonation margin decreases with oil usage, but it takes a lot of oil usage to get there. Seriously doubt 100k miles would show any loss at all.
after 200k you would probably run into valve guide or seat issues first.
Old Mar 22, 2013 | 08:10 AM
Easy Rhino's Avatar
Easy Rhino
Interesting insights there. I had not thought about poor valve guide/valve seat sealing.
What about carbon buildup fouling? Any effect?
Old Mar 22, 2013 | 08:34 AM
Don-Vette's Avatar
Don-Vette
Dirty injectors and carbon build up on the underside of the valves will also hurt performance. Another reason to add a bottle of Lucas injector cleaner every couple months.
Old Mar 22, 2013 | 08:36 AM
indyDan's Avatar
indyDan
Carbon buildup can cause detonation to occur earlier than usual, but with the electronic engine controls, and top tier unleaded fuel these engines stay very clean.
To Performance drop ?
