Window index chipped window
Old Mar 26, 2013 | 02:40 PM
cj032188's Avatar
cj032188
Default Window index chipped window
Anyone experience this? When my passenger door indexes it slam it extremely hard into the top of the door and has caused the top of the passenger window to chip and become sharp.
Old Mar 26, 2013 | 04:14 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Have you tried to re-index the window to see it it lessens the contact?
Elmer
Old Mar 26, 2013 | 04:30 PM
ChevyDave's Avatar
ChevyDave
Elmer
Elmer,
question. will OP have to disconnect battery first? i suspect yes
second question, if the power windows fuse is pulled, will that reset to 'no index' like pulling battery cable? (if you know)
Old Mar 26, 2013 | 04:31 PM
eboggs_jkvl
Moderator emeritus
Actually you just roll the window down, roll it up and index it. No need to power it down. Kinda re-trains it. Similar to pressing the "1" button to remember a new seat adjustment.
Elmer
Old Mar 26, 2013 | 04:49 PM
X25's Avatar
X25
Sr.Random input generator
He is not asking about how to re-index it. He is saying the window keeps getting scratched every time the window is pushed up by indexing. Perhaps the window itself is not correctly aligned? I have never seen this issue, and if the car is still under warranty, you should get it checked out by the dealer.
Old Mar 26, 2013 | 05:07 PM
eboggs_jkvl
Moderator emeritus
I understood his problem. I'm suggesting that the original index might have been done with the door open and it "set" itself too high???? By re-indexing, it might lower the height and stop it from slamming into the frame.
Old Mar 26, 2013 | 05:14 PM
X25's Avatar
X25
I see; makes sense.
Old Mar 26, 2013 | 05:22 PM
Jim Nebraska's Avatar
Jim Nebraska
I see; makes sense.
My '05 had this happen...on the passenger window as well. The dealership (Gregg Young in Omaha...excellent Vette service) said they had seen some info about changing out the OEM screw at the top of the window guide. They did that and things seem to be fine now.
Hope this helps...
Old Mar 26, 2013 | 05:58 PM
cj032188's Avatar
cj032188
Well after inspecting the window guide..I noticed that right where the window chipped is a screw that isnt screwed in all the way! I tried to hand tight it but I wasnt able to get it in or out :-(
Old Mar 26, 2013 | 06:15 PM
cj032188's Avatar
cj032188
to get a rough idea of what it has already done
Old Mar 26, 2013 | 06:20 PM
cj032188's Avatar
cj032188
Hope this helps...
It appears that this is my issue..I inspected the top of the guide where the window would be meeting and htere is a screw that appears to be sitting about 1/4in out. I have tried tightening by hand, but was unable to...I also tried removing it, but was unable to get the damn thing to turn and was to afraid of stripping it.
Old Mar 26, 2013 | 06:48 PM
LSD 2005's Avatar
LSD 2005
Hope this helps...
I experienced the same issue with my 05. Eventually my window would only go up half-way. My passenger side Window Regulator had to be replaced.
Old Mar 26, 2013 | 06:56 PM
LSD 2005's Avatar
LSD 2005
I honestly didn't know what was the cause of my chipped window until I saw this post. I was able to tighten the screw by hand, but only so much.
Old Mar 26, 2013 | 07:01 PM
cj032188's Avatar
cj032188
My father does autobody I am going to have him take a look at it and see if he can come up with something..I'll keep you updated.
Old Mar 28, 2013 | 12:31 PM
Jim Nebraska
FYI...the dealership actually replaced the OEM screws with new GM OEM screwsl. The new screws have a slightly different head shape and resolved the chipping issue.
Sorry it's after the fact...
Old Mar 28, 2013 | 12:48 PM
AmmoVet's Avatar
AmmoVet
I have seen this also. On the drivers side, only noticed it after the top was replaced during the recall. I thought maybe the screw was not installed all the way but when I tried to tighten it no movement. So I put a piece of foam 3M tape over the screw. Seemed to help a little. My window also has a nick where the screw made contact.
Old Mar 28, 2013 | 03:39 PM
stroked383z28's Avatar
stroked383z28
My 06 had the same problem. There was a screw that looked like it wasn't screwed all the way in but it wouldn't budge when I tried to tighten it. I just replaced it with a shorter screw. Problem solved.
To Window index chipped window
