Driver Low Beam
Old Mar 29, 2013 | 11:49 PM
ZICK's Avatar
ZICK
Default Driver Low Beam
Well looks like the factory low beam Ballast is going out, tonight I had no low beam head lights, last week it worked fine.
It works once in a while, does anyone know if I have to get a factory Ballast or is there a replacement I can get.
2007 C6 Z06
Old Mar 29, 2013 | 11:53 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Damn I would get a new Vette with that issue
Old Mar 30, 2013 | 12:00 AM
ChevyDave's Avatar
ChevyDave
there is a ballast for each side. doubt they both would go out at the same time. the number is GM 89025794 (two required, 1 each side)
Old Mar 30, 2013 | 12:07 AM
ChevyDave's Avatar
ChevyDave
relay #47 is low beam relay. there is 1 fuse for low right and 1 fuse for low left, so since both are out at same time, might be the relay, its for both..
after looking at the #47 relay, it appears there is NO other in the engine fuse block that you can swap it with (nothing there with same part number). i thought there might be, so i corrected this sentence!
remote but possible (leave it to very last...)
http://forums.corvetteforum.com/1582973586-post85.html
Old Mar 30, 2013 | 12:19 AM
ZICK's Avatar
ZICK
Sorry, Only left side is acting up!
Old Mar 30, 2013 | 12:21 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Damn to many cold ones get it straight
Old Mar 30, 2013 | 12:22 AM
ChevyDave's Avatar
ChevyDave
oh........... ok... i leaped (or is that lept) to conclusion on that one,
well, if you are really interested you could swap ballasts and see if problem goes to other side
this says left and one for right.. they are same, dont let that fool ya.. lol
http://store.gmpartshouse.com/parts/...icleid=1433662
Old Mar 30, 2013 | 12:36 AM
ZICK's Avatar
ZICK
Ill do that first
Thanks!
Old Mar 30, 2013 | 03:59 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Are you sure it's not the lamp that's intermittent? Or maybe a connector is loose?
I'd start there and hope it's not the ballast. PITA to remove.
Old Jun 30, 2013 | 11:06 PM
ZICK's Avatar
ZICK
Old Jun 30, 2013 | 11:23 PM
ZICK's Avatar
ZICK
Whats strange is, they will come on when I unlock car with remote but wont come on when I turn them on with switch
Old Jun 30, 2013 | 11:26 PM
lordofwar's Avatar
lordofwar
buy hids from corvette mods
Old Jul 1, 2013 | 12:39 AM
ZICK's Avatar
ZICK
I did the entire car has corvettemods lights
To Driver Low Beam
