Help! Locked out
Old Mar 31, 2013 | 02:03 AM
glen mason's Avatar
glen mason
5th Gear
Default Help! Locked out
Car says it does not recongize {fob}. Cannot get in car. Key does not work in rear either. Battery is on charge. Thanks for any help! Glen
Old Mar 31, 2013 | 02:44 AM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
Assuming you have the correct FOB...spray WD40 on the key and into the lock. Then insert the key and carefully work it back and forth with more pressure each time till the trunk pops open. Then you can locate the pull to open the door. Good luck.
Old Mar 31, 2013 | 03:56 AM
Just 4 2's Avatar
Just 4 2
Actually try to find spray graphite to loosen up the lock. Just had a similar issue. Doors locked and fob didn't work. Opened trunk, pulled cable alarm went off. Alarm stopped, car didn't want to start. Put charger on, finally got car started. Next day ,same thing. I thought I better get a battery. Finally replaced battery in the fob. That was the problem.
Old Mar 31, 2013 | 07:59 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Default Oh nooooooo ...............
Better to be locked out than locked in. Nothing worse than having to break a window to get out ................ With the cargo hatch open ...................
Old Mar 31, 2013 | 08:04 AM
pewter99's Avatar
pewter99
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
read....
http://forums.corvetteforum.com/c6-t...nvertable.html
Old Mar 31, 2013 | 08:11 AM
LawyerJoe's Avatar
LawyerJoe
remove key from rear and try inserting it into the car....
Old Mar 31, 2013 | 08:43 AM
pewter99's Avatar
pewter99
where???
Old Mar 31, 2013 | 09:05 AM
Swiftrider08's Avatar
Swiftrider08
Same problem after sitting all winter. Replace FOB battery. Easy fix.
Old Mar 31, 2013 | 09:06 AM
hzz's Avatar
hzz
Hope you didn't charge for that advice
Old Mar 31, 2013 | 09:10 AM
Larry/car's Avatar
Larry/car
You will not be locked in. There are emergency door release handles located on the floor at each door. Everyone needs to know where these handles are located, in an accident electrical power could not be available and if you have to get out fast this is the only way.
Old Mar 31, 2013 | 09:11 AM
pewter99's Avatar
pewter99
sarcasm.....you missed it
maxp's Avatar
maxp
Old Mar 31, 2013 | 09:15 AM
Swiftrider08
Some are just too serious! But, it is early.
Happy Easter!
Old Mar 31, 2013 | 09:34 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
well, it is almost April 1, so I guess the poster meant, take out key from fob and insert it in the door lock on the door....
but seriously, folks, cclive Chris, had a whole thread/tutorial on taking out both of our keys in the fob and trying them out many times to "loosen up" the lock. it is so true.
OP, it will feel like either the lock is stuck or the key will break. neither will happen if you keep pushing on the key. this assumes of course that this IS the key for your car. the key and lock the first few times are extremely stiff to the point of feeling like it will never work and you will break the key. keep working it esp. with some form of lubricant/penetrant.
Old Mar 31, 2013 | 01:14 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Default Are they related ?
Now that's got the basis for a great Aggi joke. Two lock outs in the same month ....................
Old Mar 31, 2013 | 01:18 PM
jackcasual's Avatar
jackcasual
LOL,LOL Best post of 2013,maybe 2012. Thx made my day.
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude Donor '08 thru '23
To Help! Locked out
Old Mar 31, 2013 | 02:09 PM
cclive's Avatar
cclive
Thanks for the reference Bill...still relevant all these years later...
http://forums.corvetteforum.com/c6-c...metal-key.html
Old Mar 31, 2013 | 02:17 PM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Uhmmmm ......... Did someone eat the ears off your chocolate Easter bunny ? My statement like some others was made in jest.
Old Mar 31, 2013 | 02:26 PM
LMB-Z's Avatar
LMB-Z
OP, are you still locked out of your car? Is it a coupe or a vert?
