Electrical problem
Old Apr 1, 2013 | 10:08 PM
seung012's Avatar
seung012
Default Electrical problem
Hello all,
My friend noticed my tail lights or rear license plate lights were not on while driving. However my turn signal work and my brake lights work. Also, interior lights were very bright for some reason.... gauge cluster, ac/heater number indicator.... all very bright.
So I pulled over and checked. When i unlock, reverse lights come on but go off and that's it.... Nothing else. Usually tail lights come on and so do the license plate lights.
Anybody had this issue?
Help will be much appreciated.
Old Apr 1, 2013 | 10:25 PM
RicK T's Avatar
RicK T
Well, you don't say what year the car is so I can only offer a real guess to check. There is a main wiring connector for all the rear lights behind the passenger side lights. It often gets corroded, especially in humid climates like yours. So I'd start there, it seems to be relatively easy. Check this thread for a little more detail, different problem but same connector involved (and check the appropriate fuses if you haven't already):
http://forums.corvetteforum.com/c6-c...t-staying.html
Old Apr 1, 2013 | 10:28 PM
seung012's Avatar
seung012
2008 z06, fuses seem fine.
Old Apr 1, 2013 | 11:44 PM
seung012's Avatar
seung012
I have checked the harness behind the passenger side and it is fine. Anyone else please?
Old Apr 1, 2013 | 11:45 PM
seung012's Avatar
seung012
Still no lights on tail lights or license plate lights.... Brake lights still work... Confused!
Old Apr 1, 2013 | 11:49 PM
lordofwar's Avatar
lordofwar
maybe bad ground somewhere.
Old Apr 2, 2013 | 12:00 AM
seung012's Avatar
seung012
I did just install the hardbar harness bar today... i don't recall any sort of ground behind there.
Problem is, during night time, my whole rear is completely black... no lights whats so ever... is there a ground wire near the seat belts...????
Old Apr 2, 2013 | 07:52 AM
seung012's Avatar
seung012
Bump
Old Apr 2, 2013 | 09:46 AM
seung012's Avatar
seung012
Ttt
lordofwar's Avatar
lordofwar
as you know vettes are glass and they have a hard time finding ground.if you just installed something and the problem started at the same time,good chance you drilled into or disturbed a ground wire.look all around where you did work and see if something is loose or pinched.
Old Apr 3, 2013 | 12:27 AM
seung012's Avatar
seung012
Figured out issue... Fuse number 5 keeps messing but so replaced with 15.
To Electrical problem
