Z51 package
Old Apr 3, 2013 | 12:12 PM
dckotwicki's Avatar
dckotwicki
Default Z51 package
I have a 2009 C6 Z51.
I have heard it has...
Stiffer suspension?
Thicker stabilizer bars?
Bigger brakes? (I can see that)
Does it have an oil cooler?
Now I think I heard that the transmission is actually beafed up too.
Anyone actually know what the Z51 option contains???
Old Apr 3, 2013 | 12:23 PM
Don 79 TA's Avatar
Don 79 TA
i think they may have made slight changes over the years??????
but i haven't heard of a trans update
i've heard rear gear ratio (but i think was another option at least on our 05 is was, 2:73 vs 3:15??)
i know this type of info has been posted before, may want to try a search
greaseable tie rod ends too, i think that was Z51 specific
i know you CAN NOT and MUST not refer to the Z51 as a model
we have Z51 police on this board who will be all over your a$$ and will cite you for things like that, so becareful... they take is SUPER serious too
i don't think you can snip them off with a radar detector either
Old Apr 3, 2013 | 12:27 PM
LMB-Z's Avatar
LMB-Z
Google it...several articles about what it contains.
Transmission cooler, larger sway bars, lower gear ratio, stiffer springs, bigger brakes, better tires.
Old Apr 3, 2013 | 12:56 PM
ALD_Z06's Avatar
ALD_Z06
Click here for Z51 content
Old Apr 3, 2013 | 01:09 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
My '05 (which is the only one I care about) has
higher spring rates and shocks,
larger sway bars,
larger cross-drilled rotors,
engine oil, transmission, and power steering fluid coolers,
Goodyear EMT tires,
revised gear ratios for 6spd or performance axle ratio (3.15) with automatic.
So...beefier trans??? Dunno, probably not.
Old Apr 3, 2013 | 01:16 PM
el es tu's Avatar
el es tu
larger sway bars,
Goodyear EMT tires,
definitely 2.73 rear ratio on the autos the manuals retain a 3.42, but the trans gears are shorter
different goodyear emts than the base
depending on the year the oil cooler will be in the radiator (earlier Z51s), or a small external one in the front bumper
the rear brake calipers have a smaller piston for a more front oriented brake bias
Old Apr 3, 2013 | 01:24 PM
Torchsport's Avatar
Torchsport
St. Jude Donor '15 thru '26
Old Apr 3, 2013 | 01:37 PM
ruxvette's Avatar
ruxvette
Well, yes and no. 2.73 is the standard automatic rear end ratio with 4spd auto and 3.42 with the 6spd auto. 3.15 is optional with the 4spd auto and 2.56 is optional with the 6spd auto. The 6spd rear end ratio 3.42, also.
All gears in the "Z51" 6spd are shorter, except fourth which is direct in each trans.
Go to the museum website and search specs for your car.
Old Apr 3, 2013 | 01:42 PM
RobLo's Avatar
RobLo
we have Z51 police on this board who will be all over your a$$ and will cite you for things like that, so be careful... they take is SUPER serious too
Old Apr 3, 2013 | 02:01 PM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
I have a Z51 model and have been cited... wait I can't say that, but really, I have a widebody C6, wait I am not allowed to say that either, crap... I have a car.... can I say that? I changed so much on it, it's not even a Z51 model anymore...
Mine is a 2006 A6 (Auto) and has 2:56 gears
Old Apr 3, 2013 | 09:09 PM
Gary '09 C6's Avatar
Gary '09 C6
IIRC, the C6 A6 has the 2.56 rear end ratio standard, with the 2.73 rear end ratio option being part of
the Z51 package. All the C6 manual trannny's get the 3.42 rear end ratio.
(when I bought my '09 coupe w/Z51, that was the result of the research I did at the time)
Old Apr 3, 2013 | 11:24 PM
Rogers 07's Avatar
Rogers 07
And badges, don't forget the Z51 badges ......
Old Apr 4, 2013 | 07:23 AM
mcandrew67's Avatar
mcandrew67
mine has the Z51 option and has 2:56 rear on an A6
Old Apr 4, 2013 | 09:47 AM
haljensen's Avatar
haljensen
Not if your profile is correct. all A6 Z51's get a 2.73 rear gear ratio. the 2.56 is only for the non-Z51 A6.
Old Apr 4, 2013 | 12:20 PM
Don 79 TA's Avatar
Don 79 TA
WOW
i'm surprised you weren't thrown into the Z51 Penetentory
i sense some attitude with you there mister and i bet the Z51 coppers don't like it either, just becareful....
never know what can happen if two or more show up at the same time, it AIN'T gonna be pretty for you...
believe me... my wife is in Z-51 violation big time... so... shhhhhhhh
be veeeeyyyyy quiet (in an elmur j fud voice)
but those panzi a$$ ***** phockers gotta go thru me first...
Old Apr 4, 2013 | 12:45 PM
mcandrew67's Avatar
mcandrew67
nope, mine is definitely a 2006 Z51 and the sticker on my rear says 2:56, so maybe they put the wrong rear on mine?
I'll look at the window sticker when I get home and see if it says anything on it.
Old Apr 4, 2013 | 12:46 PM
mcandrew67's Avatar
mcandrew67
WOW
they tried too put me in their, but my Z51 out ran them
To Z51 package
Old Apr 4, 2013 | 12:58 PM
ruxvette's Avatar
ruxvette
Correct...3:42 is the standard ratio and 2:56 is the optional ratio with A6.
Old Apr 4, 2013 | 01:19 PM
not08crmanymore's Avatar
not08crmanymore
Automatic Z51 cars do not have an oil cooler. Only manual tranny.
Old Apr 4, 2013 | 01:44 PM
GotVett?'s Avatar
GotVett?
Z51 here and the badge to prove it . . .
