When you are using the NAV is there a way to split the screen so you can see the radio presets? In my wife's SRX there is a setting to split the screen Same with my explorer Thanks
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
All the split screens on the nav are for nav functions only.
To select preset stations without going to the radio screen, select the source using voice command and then press and hold scan for 2 seconds. It will then scan through all of the presets for that source (AM, FM1 and FM2, XM1, or XM2) as opposed to the normal function of scanning for the next strongest station. Press scan again to select the one you want. Another case of not the most user friendly but, when you take the time to learn how to use it, more powerful than some aftermarket units.
