I am not one to down talk someones choices...before I bought my vette, I was a member here learning. As soon as I got it the first night on the drive home from Sacramento I brought the Owners manual in to the motel room for reading. Learn as much as you can about the cars you drive. Unless it is covered under warranty I would not bring it to a dealer. FYI a bulb change someone at Auto Zone would have done it for you for nothing that is if you allow someone else to maintain your vehicle.
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
If they didn't crack your rocker panels in the process by first putting it on a lift to remove the wheel so they could find the access panel, consider yourself lucky.
Took a little trip out of state. Service active handling system light comes on followed by check engine light a few minutes later. Car was running rough. It's 2 in the morning.I thought probably a sensor or worse. Took it to a chevy dealer. Shorted out plug wire, #5 cylinder. 234 dollars.
I do not mind paying $49 to the dealer for a bulb change considering the fact that the assess points on the Corvette is tight and you have to take the tires off to reach them..jacking is also another reason I do not want to touch it nor will I let a none trained Corvette guy work on it period. I knew coming into ownership that I got to pay to play...IJS
