battery charge
battery charge
I just put a multimeter to my battery with the engine off and it read 13.02 volts. When I was driving and used the DIC it was reading around 13.7 to 14 volts. Car starts fine but my gas gauge is acting up and Ive used seafoam and have been using Texaco to fill up. So Im wondering if the low voltage on the battery could cause the gas sensors to act up? Whats the best battery to use as a replacement?
With car on the readins were around 14.2 volts so Im guessing the battery and the alternator are good? So something else causing the low DIC readings? I remember them read a 14+ volts before and never got into the 13s.
Battery looks fine.
You said you used Seafoam. How often, how long ago?
If your only issue is the gas gauge I suggest trying "at least" 2 tanks of Chevron supplemented with a bottle of Techron each time. If the gas gauge issue is the usual sender contamination then the Techron has proven to fix that in many cases. At least it's easy and you need the gas anyway so it really isn't costing anything other than the added Techron.
Battery looks fine.
PS- Just a litlle curious why the DIC has never shown in the 13s before and now does and I havent added anything electrical.
Received 2,051 Likes
St. Jude Donor '13
Voltage shown on the DIC seems to vary considerably depending on RPM, battery charge, electrical loads, and even outside temp.
I don't get excited by any readings between about 12.7 and 14.7, with the engine running.
Of course, I'm not having any other issues ...
With the engine running the normal reading is 13.8 - 14.2.
If you have any doubts about the battery then take it out or take the car someplace and get it load tested. That's really the only way to be reasonably certain of condition.
And no, I don't know a way to test the sender. There might be a way but I don't know it.
Once the car is running and the alternator starts providing power to the system, the system voltage, which includes the battery, will be anywhere between 13.2 and 14.5 on the DIC. This is normal range and does not indicate any problems.
As for the gas gauge, it is unrelated to the voltages. Texaco gasoline is now made by Chevron and has the same Techron additive. You might also try buying a bottle of Techron and put that in with a full tank.
Thanks for the info guys, so I guess Ill keep trying the gas for a bit then see about getting the sending units checked if it still persists. Im gonna clean all the baterry connectors and posts too.
