Fluid Changes, when should they be done?
Old Apr 18, 2013 | 05:51 PM
c3s2010c6's Avatar
c3s2010c6
Default Fluid Changes, when should they be done?
I have owned my 2010 since 4/10, or 3 years ago. Even though the mileage is only 13,000 should "all" the fluid in the car be changed? Thanks all!
Old Apr 18, 2013 | 06:54 PM
v.vet's Z06's Avatar
v.vet's Z06
I have my brake fluid changed every 3 years and more often if at the track occasionally. Just had my coolant changed since the car is 5 years old. Change my own clutch fluid when dark according to Ranger's method. Hopefully you are changing your oil every 4-5000 miles or annually. Mobil 1 or other recommended synthetic.
And the rear links if you have them should be lubed at least yearly. That should about cover it!
Old Apr 18, 2013 | 07:49 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I'd agree w. the above except for one small change: I'd change the brake fluid every two years. Very inexpensive for what it does.
Old Apr 18, 2013 | 07:50 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Your mysterious Owner Manual has most of the answers. If you like to be conservative, you could do things a little sooner or even at 1/2 the normal intervals if you wish.
Since I am very conservative, I also did the following:
Differential & A6 trans at 50k miles
Power steering at 50k miles
Flush brakes every year at dealer with Tech2 to cycle the ABS. For most people, every 2-3 years would be ok; but I use the brakes hard sometimes in the mountains.
See if you can find time in your life to drive it more, your car is feeling neglected.
Old Apr 18, 2013 | 10:01 PM
LMB-Z's Avatar
LMB-Z
I try and do all my fluid changes before lunch.
To Fluid Changes, when should they be done?
