Corvette Forum Test
Old Apr 19, 2013 | 09:22 AM
garye's Avatar
garye
St. Jude Donor '12-'13-'14-'15, '21
Default Corvette Forum Test
I'm a retired educator so I am experienced in writing hard questions. Seems every test I gave over the years someone would always stand out above the rest and was very knowledgeable about the subject area. So forum brothers and sisters I have several questions, will someone or several CF members stand out??
1. RPI has colored caliper covers that snap on and tighten with a couple of screws. Has anyone bought caliper covers? If so what are your comments about how they work, lookl? Any pics available.
2. Several folks on here have mentioned that they have used a clear bra to cover the area around the rear air ducts, where do you place the material, how high, how far back etc?? I hope someone would have pics of how theres look so I can copy the placement.
3. Whats the wheel size of a GS convertible, looking to replace my rims.
4.If a boat is sitting in the ocean and tosses a rope over the side with 5 knots in it 2 feet apart. The tide rises at the rate of 24 inches every hour and a half, how long does it take for the water to reach the top knot??
Thanks for the help folks.
Old Apr 19, 2013 | 09:28 AM
Vette_DD's Avatar
Vette_DD
4.1 I've never known that a boat could toss a rope over the side. I would think a person would have to do that.
4.2 Never. The boat rises with the tide.
Old Apr 19, 2013 | 09:29 AM
GARYFINN's Avatar
GARYFINN
From: S/W ,Fla-Ohio State Football isn't a matter of life or death,Its Much More serious than that
Boat rises with the tide
Old Apr 19, 2013 | 09:33 AM
R&L's C6's Avatar
R&L's C6
Caliper covers
A- Really lame
B- Will cause mockery of said car and owner
C- Better off painting calipers
D -All of the above
Answer - D
Old Apr 19, 2013 | 09:34 AM
MLCRookie's Avatar
MLCRookie
Based on my experience as an instructional designer, question #4 would be deemed invalid as there are too many variables to make any assumptions measurable...sorry, you failed.
Old Apr 19, 2013 | 09:36 AM
arcticblast's Avatar
arcticblast
Cruise-In VI Veteran
Cruise-In VII Veteran
1. No
2. High enough and far back enough to protect the area you want protected.
3. The wheel size is the diameter/width of the wheel.
4. Very funny.
Did I pass?
Old Apr 19, 2013 | 09:38 AM
42Chevy's Avatar
42Chevy
It's 5 o'clock Somewhere
St Jude Donor '13-'14-'15
Originally Posted by JimTN
4.1 I've never know that a boat could toss a rope over the side. I would think a person would have to do that.
Old Apr 19, 2013 | 09:40 AM
MLCRookie's Avatar
MLCRookie
Garye, were you with Minot State or Minot public schools?
Old Apr 19, 2013 | 10:07 AM
philip_g's Avatar
philip_g
either way, why not minot?
Oh, I remmeber, because it's cold as ***** there.
myfunz's Avatar
myfunz
I bought them last year, and I'm taking them off! Installed them last year and noticed the fronts were scraping on the wheel, very little room for error. I went to Carlisle and talked to the vendor that sells them and explained my problem, he was ready to blame the wheels until I said they were stock. He tolled me to go to Home Depot and buy some paint to repaint them. Waste of money, I'll paint the calipers this time.
Old Apr 19, 2013 | 10:20 AM
z51vett's Avatar
z51vett
Cleartastic makes a precut piece that goes on. You can buy from some of the vendors on here. Wheel size is 18 front 19 rear check Bobs house of wheels vendor here also.
z51vett
Doug
Old Apr 19, 2013 | 10:32 AM
Matt26's Avatar
Matt26
1. Just say no to caliper covers
2. Cleartastic is a product that you can install yourself with warm soapy water. Xpel and 3M make some professionally installed products.
3. Wheel sizes
Front
19x10
Offset: 40mm
Rear
20x12
Offset: 57mm
4. Never
Old Apr 19, 2013 | 11:18 AM
garye's Avatar
garye
Des-Lacs Burlington ( HS 9-12)
Dakota Boys Ranch ( Superintendent)
All in the Minot Area
Old Apr 19, 2013 | 11:22 AM
garye's Avatar
garye
3. Wheel sizes
Front
19x10
Offset: 40mm
Rear
20x12
Offset: 57mm
4. Never
Very good except the gentleman above your post says 18/19. This is my issue with the wheels, seems there is a difference of opinion in the wheel size thus my confusion
Old Apr 19, 2013 | 11:29 AM
arcticblast
The diameter would be on your tires.
Old Apr 19, 2013 | 11:31 AM
Matt26's Avatar
Matt26
He is correct, the stock grand sport rims are 18/19
The Cup wheels and ZR-1 Wheels (available on GS) are 19/20
That may be where the confusion comes from.
Here is a vendor that has the sizes and off sets listed.
http://www.houseofwheelsonline.com/corvette_oe.php
Old Apr 19, 2013 | 01:46 PM
bcozad's Avatar
bcozad
Question 4:
Immediately - if the rope is not attached to boat.
To Corvette Forum Test
Old Apr 19, 2013 | 01:51 PM
LawrenceFromTorrance's Avatar
Actually, the top knot gets wet immediately if as was said the rope gets tossed over the side.
Old Apr 19, 2013 | 01:52 PM
ZYUL8r's Avatar
ZYUL8r
Caliper covers are never a good idea as your brakes generate heat, and they would hinder heat dissipation, and possibly melt.
Old Apr 19, 2013 | 02:54 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Thanks for the help folks.[/QUOTE]
Rope floats, unless you tie a weight to it.
