Engine cleaning
Old Apr 21, 2013 | 02:40 PM
ls1121's Avatar
ls1121
St. Jude Donor '14-'15
Default Engine cleaning
I'm going to wash the engine bay and am wanting to know what things on a C6 I need to cover. I will cover the ECU and the alternator but are there any other parts that may be hurt by the water, it will be a slow stream form my garden hose. It's my DD and was spotless when I bought it in November but has collected some dirt and I want to keep it as clean as possible.
Old Apr 21, 2013 | 04:26 PM
truckplay's Avatar
truckplay
Default Don't worry
I hose mine off every time I wash the car. Gentle spray, dry and shine every time. Done it to all my cars since I was a kid and no problems at all, even with exposed filters, those I covered with a plastic bag.
Old Apr 21, 2013 | 05:07 PM
Mad*Max's Avatar
Mad*Max
I don't cover anything but I avoid spraying the alternator and air filter housings as much as possible - just start it up after washing to dry it up. The key is to keep it clean and not let it get too dirty and you will only have to do minor touch ups.
Old Apr 21, 2013 | 07:30 PM
ls1121's Avatar
ls1121
wow Toronto, last time I was there I saw Johnny and Edgar Winters at the Maple Leaf Arena. gee did I just date myself lol.
Old Apr 21, 2013 | 07:39 PM
RHC6's Avatar
RHC6
Default Wrap
I put some cling wrap on the alternator and some over the top of the battery but doubt I really néed too. I clean mine a couple times a year is all. I use the stuff called Brown Royal by a company called Flash. Used the strong version for the engine and lower strength for the wheels.
Old Apr 21, 2013 | 07:43 PM
Mad*Max's Avatar
Mad*Max
budgreen3564's Avatar
budgreen3564
I just use Aerospace 303 occasionally.
Old Apr 21, 2013 | 10:50 PM
Like dem Vettes's Avatar
Like dem Vettes
Mad*Max, you live in a great city. I used to visit Toronto a lot when I lived in Buffalo.
Old Apr 21, 2013 | 11:19 PM
ls1121's Avatar
ls1121
I went to Advance and bought a bottle of Purple Power Citrus Cleaner, I'll spray it on everything and then hose it off and see how it looks. I do have some 303 on hand to do the plastics after they dry. I went to a local car show on Saturday but did not show my car because it was dirty. That won't happen again. Thanx guy's for your help.
Old Apr 21, 2013 | 11:26 PM
Bill Dearborn's Avatar
Bill Dearborn
I use a 50/50 mix of Simple Green and water in a 16 oz sprayer. I spray the complete engine compartment and then let it soak for a few minutes and then use a hose to gently rinse the engine down. If you don't mind things dripping for a while use the mixture on the hood insulator and then use the hose to gently soak the insulator to get the dirty solution out. Once you get everything rinsed close the hood and start the engine and let it run for 20 or 30 minutes to dry things out. You can wash the rest of the car while the engine drys.
Bill
Old Apr 22, 2013 | 07:55 AM
ryoder's Avatar
ryoder
I once destroyed the alternator in my grandfather's 5.0 powered Lincoln by using too much water.
Old Apr 22, 2013 | 10:10 AM
ButWhatDoIKnow's Avatar
ButWhatDoIKnow
Some of us find that if we spray with detailer or 505 on a regular basis, that is all they need.
Old Apr 22, 2013 | 01:03 PM
cclive's Avatar
cclive
You can not cover the ECM anyway as you can't get to it. Cover the alt and fuse block with plastic grocery bags and have the engine just warm before you clean it...not hot, just warm, as if you had driven it a couple of hours ago. I spray with 409, let sit for a couple of minutes and then rinse. Leave hood open...warmth helps it dry faster. Remove plastic right after last spray, don't leave it on while drying as condensation can occur under the plastic.
Old Apr 22, 2013 | 04:44 PM
wayback's Avatar
wayback
I used to rinse my eng bay with low pressure spot free water at the car wash, avoiding the alt. Had water enter the MAF connector and my eng went bezerk(this was 2 weeks after I washed it). Had it towed to shop as it was not driveable. They found the wet connection and blew it out with air then left it unplugged and sitting in the sun all day....no more problem.
Now I use detail spray and a micro fiber towel.
Old Apr 22, 2013 | 05:43 PM
Mad*Max's Avatar
Mad*Max
thanks, I've lived here most of my life, traffic and weather are the biggest downsides
Old Apr 22, 2013 | 08:41 PM
ls1121's Avatar
ls1121
yea but you have a Great Summer......both weekends.
Old Apr 23, 2013 | 04:20 PM
ls1121's Avatar
ls1121
Sure that is OK for the big things but how do you get your fingers into places smaller than them??
I did both cars today and just covered the alternator with a plastic bag, let it sit for a couple minuets and then rinsed it off, closed the hood and let the car run for about 20. Looks good. Thanx!
To Engine cleaning
