Foam gun
Old Apr 22, 2013 | 10:46 PM
808c6's Avatar
808c6
Default Foam gun
Tried using the foam gun hook up to the garden hose, noticed the pressure might not be strong enough to cause foaming? Any suggestion ? TIA
Old Apr 22, 2013 | 10:51 PM
RicK T's Avatar
RicK T
Could be the pressure, the gun or the soap. What gun do you have and what soap?
Autogeek's gun says it works best at 40-60 PSI which is pretty typical for residences.
http://www.autogeek.net/auqufofogun.html
Old Apr 22, 2013 | 11:02 PM
808c6's Avatar
808c6
The gun with the orange top and brass fitting from my detail guy, DP streamed foam for soap.
Old Apr 23, 2013 | 09:02 AM
spdkilz911's Avatar
spdkilz911
That's the one I have. I use Adam's carwash and it works fine. We have high pressure also. Low pressure may be the problem.
To Foam gun
