using Helicoil?
Old May 2, 2013 | 01:33 AM
NARIMAN's Avatar
NARIMAN
Default using Helicoil?
i stripped threads where upper control arm attaches to the frame
i wanted to buy Hellcoil and wanted to ask if it is safe for such aplication
or better get timesert?
it is easyer to get helicoil from parts store
Old May 2, 2013 | 06:25 AM
Don-Vette's Avatar
Don-Vette
To install a hellicoil, you need to drill and tap a larger hole (using the hellicoil thread chart),then use a hellicoil insert tool to screw it into the bottom,back out the tool and break off the tab on the bottom. Make sure you tap those threads straight!
http://www.helicoil.com.sg/HeliCoil-...ructions.shtml
We use the free running inserts at work.....
http://www.helicoil.com.sg/HeliCoil-...rt-Types.shtml
Good luck!
After reading about the timesert,I think this would be a better application for your job...
http://www.timesert.com/
Old May 3, 2013 | 12:51 AM
NARIMAN's Avatar
NARIMAN
thanks
Old May 3, 2013 | 07:49 AM
ben dover's Avatar
ben dover
From: When all is said and done... there is a hell of a lot more said than done. Riverside,Texas
St. Jude Donor '05 thru '26
I like keensert. Standard tap size.
Old May 3, 2013 | 10:15 AM
Biggie G's Avatar
Biggie G
dude....sorry but this takes skill to use or else you will make it worst. dont F with it. have someone experienced perform this task.
Old May 3, 2013 | 10:17 AM
boraxman's Avatar
boraxman
Old May 3, 2013 | 12:03 PM
LFZ's Avatar
LFZ
I don't see why a properly installed helicoil wouldn't work. I accidentally stripped out the rear upper shock mount bolt on my other vehicle. I drilled it out, tapped it, installed a helicoil, torqued the bolt and never had a problem.
Old May 8, 2013 | 12:09 AM
NARIMAN's Avatar
NARIMAN
fixed it was super easy
thanks
Old May 8, 2013 | 07:36 AM
johnny3's Avatar
johnny3
Which type/method did you use?
Old May 8, 2013 | 09:10 AM
Larry Myers's Avatar
Larry Myers
When I was in the aircraft maintenance business we always used helicoils. However, this was over 25 years ago so wouldn't be surprised, if today, there is not something better.
Old May 8, 2013 | 09:33 AM
johnny3's Avatar
johnny3
I've got 40 yrs machine shop back ground also, heliacoil, nothing else, the threads are aircraft quality, just curious as to what op used.
To using Helicoil?
