Dynamat review...
Dynamat Extreme to the bulkhead behind my
seats. No pics, as I am sure you have seen
it all before. Amazon had a great price of
$142.00 for 36 sq feet.
I Lifted up the carpet as instructed on previous
posts. I cut and shaped sheets to the entire
bulkhead and each side wall as far as I could
reach, forward.
I slid pieces under the carpet floor, forward, as
far as they would go. I also tucked black foam
rubber I had under the Halo trim. It had a
lot of room with hand movement and space
so I thought this would help.
A point on the Dynamat installation. Only
peel part of the backing off before
application. This gives you more control
over placement. Also, go with half sheets
if you are covering a large area with
cramped spaces. Again, this is for control.
Ever wrestle a gorilla?
Use Dynamat tape for any spaces. Get
the wood roller to smooth it out.
I got everything back in place. I have done
no insulation in the cargo area yet. I went
on a one hour drive on my city and tollway
roads here in Dallas.
The biggest thing for me was a loss of a
low pitched, coarse vibration in the back of
my neck while driving. The tire noise was more
outside the car now and the road bump
vibration was at least 50% decreased.
The Bose stereo sounded much better,
clearer, more depth in the music. By the
way, I am not a Bose fan.
I recommend this mod to anyone. I am
not pushing Dynamat, but after all my
reading, it seemed the best to try for a
one time install. I am inherently lazy.
I will do the cargo area next. I am also
still considering a Block-It on top of
this install after Dynamat is complete.
sq feet on the bulkhead.
Plenty left to begin the cargo area.
I think I read 42sq feet for the entire
car. I have not, and don't plan to
remove the carpet in the passenger
area. Just sliding it in where I can.
FWIW, I was doing some big interior work the other week and I lined the whole center tunnel with it (mostly to help reduce the heat in the tunnel). Heat dropped a decent amount (though I'd still prefer less) but the car's noise dropped quite a bit, especially around the drivetrain (the low rpm 1st gear 'marbles' sound & injector tick).
The stuff really does work. I don't think I'd go crazy with it as I'd be concerned about the amount of weight I'd adding to the car but I do think it could go a long way in reducing noise if applied in moderation in select areas.
Sorry. Most of all I read was in this forum. A lot of stats are on Crutchfiled and the Dynamat sites. I searched Insulation, Dynamat
etc... I may be off on the total square footage, about 50
sq feet without the doors.
The bulkhead was only difficult because of the tight area to work in.
I sat on the door sill and cussed a lot. I just raised the carpet
up how it naturally drapes down. I slipped and crammed it
any where else to leave as much as close to factory build as
possible. Not difficult, just tight.
When I put in the M2W, I slipped Dynamat under, or stuck
it to each surface I could reach. Read the stats. You are
not adding enough weight to change your speed much
on the street. If you are a tracker or sprinter it might
change your dyno's.
Put down the Dynamat first , Then
Reflectix on top of that. I looked
for Thermo-Tech locally, no luck.
So I used Reflectix I found at
Home Depot. Very inexpensive
by the way. I also put
Reflectix under the storage bins.
I put black rubber foam
behind the walls covering the
speakers. Just blank air under there
and prime for a rattle.
Results are, no cargo noise at all.
I can hear the exhaust actually
better. Tire noise is all outside the
car now. (GY's.) Couldn't be
happier.
Put the LED's in while I was there
too.
Sorry for the crappy iPhone pix.
My 300mm was all I had on the
35mm.
I will follow up on the heat
changes. Thx!
Your Welcome.
Yes, Reflectix. I went down to the far end of
the A/C filter isle. One isle over to my right , on the end , was Reflectix.
24ft for $11.00. There are threads containing Reflectix here.
I have not checked them out. But the stuff is easy to work with.
Get extra Reflectix Tape. This is not peel and stick. I ran out
quickly and used my left over Dynamat Tape.I almost
used one complete roll on the cargo area. I bought two. I plan
to do more in the passenger area.
I had slid in under the console storage area.
The thermometer was at 95 F after the car sat
for a couple hours, in the garage with windows
and console lid shut. Garage open, about 85 F
outside.
Went for a 30 min ride on the tollway. The
temp in the console went down 3 degrees
to 92 F after the ride. Much cooler In the
stock console. Except for the 1 inch closest
to the shifter. A quarter sitting there was still
very hot. I guess I missed the last inch or so.
The car is much tighter over all.
Bottom line is Reflectix works well and is
cheap. I say go for it!
Really cut own on the exterior sound. I drive about 90 miles each day, and like to listen to the iPod. I still have some rear tire noise (GY run flats) that I need to figure out, but a Bigg improvement. Worth the work.
