Header questions
Old May 9, 2013 | 11:41 AM
Mdrforce's Avatar
Mdrforce
Originally Posted by speedraider
stay away from LG super pro's , they are leak at every slip joint. You will be pissed if you buy them.
Not trying to be rude or disrespectful, but did you install these headers yourself (garage) or did a shop install them? I'm in the process as well of looking at headers and have heard this leak at slip joint on LGs. The only trend I see is more home garage install with leaks vs shop install.
Old May 9, 2013 | 11:44 AM
beepster's Avatar
beepster
Originally Posted by lebvette
Melrose would be another brand to consider. They are American made...coated inside and out.
Your original post mentioned heat as an issue. I had a set of Melrose (ceramic coated) headers on my '07 and you could literally rest your hand on them within 10 minutes after turning off the engine...excellent quality and fitment.
Old May 9, 2013 | 12:28 PM
irok's Avatar
irok
Originally Posted by dealer06
I completely believe you, and I'm definitely not knocking your choice. I only note that on this and other forums like the camaro forums, there were a few who were disatisfied with fitment. I've never heard anyone dissatisfied with, for example, Kooks, Phadt, or ARH. Until Speedraider's post above, I had never heard even a single negative comment about LGs, either.
I did read that the earlier OBX had fewer problems than the more recently produced ones. Have you had yours for a while?
I see the VetteDoctors offer a pretty good deal on ARH, installed and tuned. That may be the way to go.
I have had mine on the car for approximately 1 1/2 years without any problems. my car is a LS2 and picked up 60 rwhp with the OBX headers and Fast. cost me approximately $1,900. installing myself.quite a savings compared to other headers where I have seen them charge as much as $2,900. for headers alone.need someone to chime in with a LS3 car that has installed them about fitment.Or get a $1,500 t-shirt for free!
Old May 9, 2013 | 03:23 PM
Pfadt Racing's Avatar
Pfadt Racing
There are several things that separate headers. There is lots of crap out there, and we won't really mention those. Once you get to the top, it becomes a race to be the best. At the top everyone makes a really good product that we are proud to put our name on.
What I would say about the Pfadt headers isn't just that the Fit&Finish is excellent along with the craftsmanship, but there are two features that we try to use to distinguish ourselves.
1. The Tri-Y design. Our engineers determined this was the best way to optimize the power curve for our cars. Flow restriction is only part of the story when talking about power, the other part is the geometry of the piping as that correlates to the exhaust pulses that need to time with the valves for optimal performance. Basically, the geometry is critical for exhaust pulse tuning
2. Our flange design vs. other brands slip fit. Our flange won't leak. Period.
I think you'll be happy no matter what though. Headers make an LS sound the way it was supposed to when you lay on the gas
Old May 12, 2013 | 10:37 AM
RHC6's Avatar
RHC6
Default For what it's worth
I have had the PHADT Headers for about a month now and could not be happier - their quality is second to none and the torque these suckers pull out of your engine is sick! HAIL TO THE PHADT TRI-Y's
