Yellow Caliper paint to match Velocity Yellow?
I've decided to paint my calipers yellow and bought a POR-15 yellow Caliper paint kit. Problem is that the yellow does not match. Has anyone else used a yellow caliper paint on their Velocity yellow vette? What mfg has a color which is close to the VY?
BTW, G2 has a custom match but it is $100. I may consider powder coat if I have to pay that much. I was trying to save a little $$$. But it seems that hardly ever works for me
If you've not checked out Dupli-Color?
Available at most parts stores, might give 'em a look.
Used DC on my '06 Z51 car, and while I used red it turned out pretty good. Bet DC's yellow isn't bad, either.
Otherwise, powder coating may be your only other option.
Bump. Help! I need a yellow caliper paint which comes close to matching Velocity Yellow. Anyone know if G2 or duplicolor is close? POR 15 isn't very close at all
I have a color swatch coming from G2. The color on their site looks close. But that's not a good reference. The only Duplicolor kits I can find in town are red. I know that their yellow engine enamel is not a match. But I don't know about their caliper kits
Go to your local auto parts paint store and get them to mix you a can of spray paint in your paint color. Then it will match your car. Just clean real good, mask off what you don't want painted, an put on 3-4 light coats.
Thanks for your reply. From what I have read, the paint stores do not/cannot mix high temp paint. I am going to check with the store which I bought the kit from. They are an auto paint supply store.
It doesn't have to be high temp paint. I painted mine when I had my 05 with regular paint and never had a problem in 4 years. Only thing I did was I used the DupliColor kit first and then spray painted them. I still have the can of spray paint.
Do you track your car? If not, you don't need high temp paint. Your calipers will never get that hot. I used Krylon from WalMart on my 2006 about 6 years ago that came close to matching Monterey Red and it still looked good when I traded it last July. I've also used a color close to millennium yellow on my wifes a number of years ago and it's still going strong. The secret is getting them good and clean before you paint them. I usually wash them down a couple of times with laq thinner. Spray light coats not wet coats.
$450 for PC and installation vs $50 and some of my time for painted. I'd like to have the PC's. But I am retired and have other mods in mind also. IOW's I have more desire than $$$. But isn't that always the case?
Same here touch up paint and looks great after 2 years.
