A-6 Mishap
Old May 12, 2013 | 06:00 PM
AeroJim's Avatar
AeroJim
St. Jude Donor '08-'09
Default A-6 Mishap
Great day for a ride here on LI with the top down today.. It almost got runied because of the following mishap that was my fault. Long story short, I went to merge on a busy parkway at about 40 MPH and almost caused an accident.. I honestly thought that when the transmission downshifted I would have enough room to accelerate and safely merge. What had happened though was I was in drive and had previously downshifed with the paddles prior to the merge.. the hud indicated the transmission was in 5th gear.. Anyway out I came floored the car to hit passing gear( down shift) and nothing happened.. The car did accelarate, but not to quickly at all, no down shift at all..
Was the lack of a downshift when the car was floored because I had previously used the paddles and the transmission was holding in 5th gear? Should I have used the paddles to downshift further before the merge? My lesson learned here is I'll keep the frigging car in drive or buy a manual the next time around.
I really felt bad because I pissed someone off that came real close to hitting me in the rear end...I never expected the car to do this.. When my 05 A-4 was floored at 40mph the transmission downshifted and the car would really haul ***.
Old May 12, 2013 | 06:17 PM
TerryL's Avatar
TerryL
St. Jude Donor '17
In my 06 I have to be in D in order to be in full automatic which includes downshifting by merely pressing on the gas pedal. The HUD tells me which mode I'm in due to the gear indicator which doesn't exist in D. All you had for passing power in such a high gear was the torque from the motor. You could have hit the upshift button a couple times and found the gear you needed. If you use the paddles you have to think like they're similar to a stick and for the most acceleration you have to choose the right gear first.
Old May 12, 2013 | 06:21 PM
SK360's Avatar
SK360
When in paddle mode it will not downshift automatically unless you are coming to a stop in 3rd or higher. This is expected and normal behavior. You have to put it back into D to get back to auto mode.
Old May 12, 2013 | 06:22 PM
Vette_DD's Avatar
Vette_DD
Once you use the paddles, it's not going to automatically downshift unless you're slowing down. If you want it to downshift so you can accelerate, you've got to be in automatic mode without the paddles.
Old May 12, 2013 | 06:24 PM
peter pan's Avatar
peter pan
Life Time NCM #2196
Got to go back into D in our 09, it was changed in a different year and do not remember year and how it works different than our older years.
Old May 12, 2013 | 06:33 PM
Mad*Max's Avatar
Mad*Max
Old May 12, 2013 | 06:51 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Originally Posted by TerryL
In my 06 I have to be in D in order to be in full automatic....................
S Auto mode is the same as D if you don't use the paddles. It just performs a bit better.
They changed the paddle mode so you could exit back to full auto just by holding down the + upshift button (2011 or 2012?)
In the newest cars you can use the paddles briefly while in D, but it will return to auto in about 10 seconds.
In any case, if you are using the paddles, you have to plan ahead, just like with a manual trans.
Old May 12, 2013 | 06:55 PM
ExRedRacer's Avatar
ExRedRacer
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Originally Posted by AeroJim
...Was the lack of a downshift when the car was floored because I had previously used the paddles and the transmission was holding in 5th gear? Yes.
Should I have used the paddles to downshift further before the merge? Yes.
Simple user error.
The main error I've committed with the paddles is a couple of times when I was thinking to up-shift from 2nd to 3rd but not being familiar with it at the time downshifted back to 1st. Sounded like my engine was going to over-rev and fly apart...but all was well.
Took a little practice before I was completely familiar with the system and now I use the paddle shifter regularly to the point where now, it's a blast to down-shift, get those revs up, and fly. Those Corsa's make it sound real exciting too and add to the fun.
I'm still amazed how the Corvette can drive just like any other ordinary car, docile, quiet, good gas-mileage, etc., but when you push that pedal with some authority and use those shifters, it transforms itself into a real race-car.
Love it....
Old May 12, 2013 | 08:22 PM
N2TU's Avatar
N2TU
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18
Originally Posted by Red Racer
Simple user error.
Love it....
Yea, I just did that today!...first time ever....pulled out onto a straightway and thought I upshifted but downshifted instead...I woke up very quickly when I heard the revs and saw the tach.
Brain fart...pure and simple.
Old May 13, 2013 | 08:31 AM
AeroJim's Avatar
AeroJim
Thanks for all the info everyone.. Lesson learned on my part.
Old May 13, 2013 | 09:01 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
the sad part is this could've been a real tragedy if that other car hadn't been able to account for a very slow car merging. which makes me wonder about all the "DCT" transmissions being asked for the C7---I wonder if they will do the same thing, and if so, what effect that will have on merges?
Old May 13, 2013 | 09:14 AM
SK360's Avatar
SK360
It's called being attentive if not in automatic mode. Just like driving a manual, you need to downshift.
Old May 13, 2013 | 09:32 AM
jpee's Avatar
jpee
This thread is EXACTLY WHY I LOVE MY (A4) Transmission in my 05 !!
Old May 13, 2013 | 10:00 AM
ParisTNDude's Avatar
ParisTNDude
I've been using my paddle shifters more and more often in recent days. I love the decel sound of the exhaust when down shifting, but in drive, it's not as pronounced. The only problem I find is, when executing a 90 degree turn...the paddles seem always to be in the wrong place of the steering wheel radius to make a smooth shift unless you want to hold the lower gear to an unnaturally high rpm. Most of you will know what I'm talking about.
My car shifts strongly to lower gears in S mode but only if you haven't used the paddle shifters. Shift to D and back to S gets me ready for my next downshift. The experts tell me S mode, with quicker and firmer shifts, will prolong the life of your tranny over smoother, slippier shifts in D drive.
Old May 13, 2013 | 10:16 AM
Don-Vette's Avatar
Don-Vette
When using the paddles you are in manual mode. Read your owners manual people!
Old May 13, 2013 | 10:23 AM
z51vett's Avatar
z51vett
I hated all the c6 autos from 05 till 2012 when they reprogramed the trans to be quicker at down shifting. While driving wifes vetts not mine I would change lanes and be in the next lane before it ever kicked down almost ran over a few cars till I learned this.
z51vett
Doug
Old May 13, 2013 | 10:30 AM
SPDKNGG's Avatar
SPDKNGG
Install a Tr-6060 trans and call it a day...
Paddles are women vette owners...lol!
J/k!
Glad you didn't get rearended.
I would never buy an automatic sports car.
To A-6 Mishap
Old May 13, 2013 | 10:38 AM
SK360's Avatar
SK360
shouldn't be shifting in corners anyway.
Old May 13, 2013 | 11:23 AM
Mike Campbell's Avatar
Mike Campbell
SK360:shouldn't be shifting in corners anyway.
I never do that. But my worst A6 event was I one time while running my car at Englishingtown. I used to do my burnout with the paddle shifters and keep it in first then shift it back to drive and back to S during my stage time. Well, I was running in a bracket and made sure to check that my dial in was correct and I forgot to shift it out of paddle mode into drive and back to S. I got a great light and then when it didn't shift I thought I blew the trans and almost soiled myself. I paniced and went to shift into drive and pushed the shifter too hard and into park. Believe it or not I slowed down and thought I'll need to be towed. But I shifted out of park, into S and it drove off like nothing happened. Wow! That was 3 years and several thousand miles ago.
Old May 13, 2013 | 11:45 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Good to take note of !
