A local car shop recently shut down in my home town and i was able to get a set of front baer eradi speed rotors for very cheap brand new. unfortunately, these are for the base c6 and i have a z51 car. the diameter of the eradi speeds are just slightly smaller than that of my stock z51 rotors. the brake pads stick out maybe a 1/4 inch past the rotor. If i were to just install these would there be any dangerous side effects? or possible damage to my car? or should i just try to sell them on the forum and cut my losses? I was really looking forward to adding these to my car :/
will i still be able to use the same calipers? or are the standard and z51 calipers already the same?
They're basically the same. The difference is the piston in the rear caliper is slightly smaller in the Z51 version.
I have used base rotors on my F55 car (same brakes as Z51) for the past 50K miles, because the GTO spare wheels won't fit with the larger calipers. I only use those wheels at the dragstrip, but don't want to change rotors anymore.
I've had a lot of 125 mph stops that seem no different from the other rotors with 2% more surface.
Pads will make far more difference than rotor size.
I'm no professional mechanic, but every part of me is thinking no go. Overhang cant be a good thing...in almost any reference. Sell them on eBay or Craiglist for a profit if you got them for an amazing price.
All you need is the smaller brackets. Its the same pads and calipers. Only the rotors and brackets are different. It is an easy swap. Personally I would sell them and stay with what you have.
