Radiator Removal
Old May 21, 2013 | 10:06 AM
iw172's Avatar
iw172
From: Retired early,everyday is Saturday...Hocking Hills Ohio
Default Radiator Removal
are there any special tools required to get the 2 silver lines w/hex nut that are on both sides of the plastic end tanks or do you just back off the hexs w/ a wrench to remove the lines? I have to replace mine and don't want to incure more expense. thanks, Mark...
Old May 21, 2013 | 07:11 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Yes, they make a tool for such a task. I have found in most instances that it is easier to remove the clip with a pick. You won't need a new clip if you lose one, but I save them.... just in case
They come in different sizes but this is the 3/8"
http://www.sears.com/shc/s/p_10153_12605_00996387000P
Since you are replacing the radiator, you could remove the fittings and then remove the fitting by removing the clips with a pick
DO NOT REMOVE THE FITTING FROM THE NEW RADITOR !!!!!
The line will snap in. Give it a tug to ensure it's locked in.
Clip
Old May 22, 2013 | 08:19 AM
iw172's Avatar
iw172
Clip
thanks Glen
To Radiator Removal
