C6 GS Tire Pressure Monitor Question
I run drag radials on OEM rears without tire pressure sensors on my C5. I get a periodic "Service Tire Pressure Monitor" on the DIC that is removed by hitting the reset button. Will this be the same on a C6 GS or are there more problems running without rear TPMS?
I don't know about getting it to go away with the reset button, but I got that exact same error for about 15 minutes a few days back. Also showed rear tire pressure on the tire in question as "XX". In addition there was the yellow warning icon lit up on the dash (cut away view of a tire with an exclamation mark in it). In my case, it went away all by itself after being parked for a few hours at work. I monitored the tire pressure in the DIC for a day and all was well....I'm just chalking it up to a glitch for now.
Cruising
