Paint???
Old May 27, 2013 | 10:14 PM
bigasswop's Avatar
bigasswop
Default Paint???
Can polished aluminum wheels be painted? I like the wheels I have currently, but, on a white vette, I think Black would look much better. Can they be painted and turn out right. Don't want to ruin them.
Old May 28, 2013 | 08:09 AM
mickey5's Avatar
mickey5
powdercoat.
Old May 28, 2013 | 08:13 AM
dvilin's Avatar
dvilin
Try Plastidip, if you do not like the look you can just peel it off. Like the look than make a decision on powdercoating them or perhaps buying a set of black wheels.
Old May 28, 2013 | 09:05 AM
speedraider's Avatar
speedraider
Originally Posted by mickey5
powdercoat.
plasti dip looks cheap
Old May 28, 2013 | 09:46 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I'd try the above suggestion unless you're absolutely certain black is the color you want. Then, I might go with the powder coat altho durable paint applied properly will work. Stock wheels on all C6s are painted I believe I read.
Old May 28, 2013 | 10:06 AM
bigasswop's Avatar
bigasswop
Thanks everyone for the advice. Plasti dip to see if I like the look isn't a bad idea.
Old May 28, 2013 | 12:00 PM
KB9GKC's Avatar
KB9GKC
Hello,
I am certain that your polished aluminum wheels already are clearcoated. You should be able to gray scotchbrite them and paint them the color you want.
If they were not clearcoated the aluminum would oxidize fairly quickly and look crummy unless you seal the aluminum with Rejex or Wax.
The polished aluminum rims should be treated as any painted surface with a good polish and my favorite, Rejex!
Douglas in Green Bay
Old May 28, 2013 | 04:20 PM
Cravinmohead22's Avatar
Cravinmohead22
If you do decide powder coating is the way you want to go, what do you do about the plastic center caps? Wouldn't it be near impossible to match color and sheen if you tried to paint the center caps?
Old May 29, 2013 | 09:45 PM
speedraider
center caps have to be painted, had mine done and they matched perfect
To Paint???
